SneedSpeed R53/R56 side splitters go on sale 5/8 at 10am
Old May 7, 2015 | 02:45 PM
SneedSpeed's Avatar
SneedSpeed
Announcing a sale on two pairs R53/R56 side Splitters starting tomorrow at 10am. 30% percent off regular list price. There are only two available, so get them before they sell out!!
Clean up the side profile of your MINI R53 Cooper S with our black HD polyethylene side splitters. Easy to install and made of the same material that our, life time guaranteed, front splitters are made of, so you know they won't break or fade. Stock lift / jack blocks are retained, side splitters are installed to the MINI factory plastic side skirt with supplied hardware. Complete kit for 1 car and includes all mounting hardware.
Installation is very easy as the side splitters are pre drilled for mounting. Hold the side splitter up to the under side of the car's side skirt, mark holes to drill through factory side skirt, drill holes, install bolts through side splitter and skirt and tighten nuts on top side of skirt. You pull the skirt down under the car to get to the inside of it. Should take about than 1 hour to install.
Get yours while they last!
http://www.sneed4speed.com/r56-mini-...side-splitter/
http://www.sneed4speed.com/r53-mini-...side-splitter/
Old May 8, 2015 | 10:23 AM
SneedSpeed's Avatar
SneedSpeed
I totally blanked, got busy tuning on the dyno and forgot to post the sell at 10 this morning . Sorry y'all. Here's the coupon code 30flash Get the side splitters while their hot!
Chris
Wohnson89
Jun 10, 2020 04:53 AM
ej
Sep 28, 2015 05:41 AM
cm.d
Aug 19, 2015 08:51 AM
Indimanic
Aug 14, 2015 03:14 PM
CM2011RG
Aug 5, 2015 02:00 PM
