loads of fault codes
Old May 7, 2015 | 02:27 PM
a2oc's Avatar
a2oc
Hi guys, I've just plug my pc to my mini and there's loads of fault code popping out from my car. Can anyone help me to decode them?
SZL: C994
DME: 275F, 30A8
EPS: D517
CAS:A0B6
KOMBI: A3D2
MOSTGW: E194
And it seems that all of them doesn't happen once as the car has logged 20+ times of every each of those codes. No warning lights on dash though.
Old May 7, 2015 | 04:13 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Are you having car issues or just playing? I'm no expert but I think you might need to drill down to each module in the software (not sure what you are using) to get a better description of what is going on. Could just be nothing if you don't have any engine lights or other issues.
Old May 7, 2015 | 04:23 PM
a2oc's Avatar
a2oc
most of the time it feels fine, but sometimes it does act up........ looks like i need some time to dig those codes......
Old May 7, 2015 | 04:56 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
With what you find with those codes, you may be able to find some more help on the fixes here in our tech articles. Good luck!
-Luccia
888.280.7799 | 6am - 5pm PST
Old May 7, 2015 | 06:25 PM
AZdsrt's Avatar
AZdsrt
This is where I go to decode generic codes -
http://www.obd-codes.com/
Old May 7, 2015 | 10:15 PM
Minnie.the.Moocher
http://www.e90post.com/forums/showthread.php?t=901278
Old May 7, 2015 | 11:13 PM
a2oc's Avatar
a2oc
tried that and all of them are in german :( I doesnt know any german except aktiv and nicht aktiv lol........... But most of them are saying things below threshold and happen for a couple times...... I'm going to the dealer very soon, should I ask them to fix those bunch of codes instead of 'wait and see' thing? Apparently dealers are pretty good on deleting all my codes and they pop up within the first week after i got it back. But those symptoms arent really easy to tell unless you drive it everyday and some of them are really intermittent :(. Still got the mini XL warranty left on my car.........
Old May 8, 2015 | 02:27 AM
scubbysnacks's Avatar
scubbysnacks
Have you thought about purchasing the BMWhat app. When I used it to check for codes it even pulled old bulb out codes. Which could explain some of the the codes that your seeing but the car is running fine. Bonus is you can us the app to do a little coding.
Old May 8, 2015 | 09:56 AM
a2oc's Avatar
a2oc
I have, but that app is so expensive to use. $40 for adaptor and 60 for the app itself. I use the old fashioned NCSexpert to code my car and i saw those codes in INPA.
Old May 8, 2015 | 03:28 PM
scubbysnacks
Yeah its expensive but I use the same Bluetooth dongle that I use with Torque on Android.
I just suggested it because when you check for faults you get the code and description I haven't used NCSexpert so I don't know how much detail it gives you from you post I assumed it just gave you the code and you trying to find out what it means. BMWhat gives you that info automatically in English.
Last edited by scubbysnacks; May 8, 2015 at 03:45 PM. Reason: Language used in description
danielbrookes_9
Oct 3, 2015 12:51 PM
Chasp
Sep 4, 2015 09:31 AM
reg66
Aug 31, 2015 02:41 PM
bcman
Aug 28, 2015 04:47 PM
scottrn
Aug 22, 2015 07:26 PM
