R56 Not the Turbo Oil Feed line?
Old May 1, 2015 | 05:34 AM
boatman2500's Avatar
boatman2500
Hey,
What is that second line on the top of the turbo?
Mine is very rusty and might need to be replaced.
Old May 1, 2015 | 05:53 AM
Coolant line.
#5 For the N14 engine you have pictured above. up to 2010 Cooper S / up to 2012 JCW
http://www.ecstuning.com/Search/SiteSearch/11537567849/
Dont forget the banjo bolt and washers if you do change it.
http://www.ecstuning.com/Search/SiteSearch/07119905973/ES2673307/
and
http://www.ecstuning.com/Search/SiteSearch/07119963201/ES2597254/ x 2
Most people change them due to the connection that goes to the bottom of the expansion tank, because they can leak there over time from oil changes and moving the expansion tank. That's the quick release end.
After replacement you will need to re-bleed the coolant for air in the system. At the top of the thermostat housing.
Top off with MINI coolant after replacement first.
http://www.ecstuning.com/Search/SiteSearch/82140031133/
Old May 1, 2015 | 04:14 PM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
Your oil line is leaking, too.
Oops. You said it wasn't your car. Too bad I can't delete...
Old May 4, 2015 | 05:45 AM
Is that cut away ( smaller pic ) your actual MINI pic ? If so then yea the top oil line looks like its leaking.
Old May 4, 2015 | 07:56 AM
boatman2500
Thanks for the great replies!
I'll be replacing both oil and coolant lines this summer.
The pictures I included aren't of my engine, they're just from a google search of the R56 N14.
Being in Canada has restricted where I can get replacement parts though.
Old May 4, 2015 | 11:47 AM
05r50's Avatar
05r50
Outmotoring will ship internationally. Check them out at www.outmotoring.com
So will Detroit Tuned. http://www.detroittuned.com/shipping-returns/
Both vendors have a better then OEM replacement oil turbo line. It is a Detroit Tuned item.
Old May 4, 2015 | 11:57 AM
boatman2500
I was really interested in the DT lines but shipping + customs fees to Nova Scotia is quiet the premium. I'm probably just going to go the local Dealership for OEM replacements.
sevin
May 2, 2026 06:11 AM
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
devicemanager
Jun 17, 2016 06:18 PM
PelicanParts.com
Aug 14, 2015 11:07 AM
