Cel 2f07, 08 r56s
Old Apr 30, 2015 | 09:32 AM
santypnoy4's Avatar
santypnoy4
Cel 2f07, 08 r56s
Hey guys, I was wondering if someone could help me out. I got a CEL of 2F07 which it seems to be related to thermostat. I have searched in this forum to get more info about this but did not came up with any definite answer.
I have read that this year and model is prone to the thermostat failing and among other things so this might be the case with mine. I did not have any issues with my car but i just hit 81K so it must be around that time for things like this to come up. Do i just replace this part? how hard is this to DIY? Thanks!
Old May 6, 2015 | 06:48 PM
santypnoy4's Avatar
santypnoy4
any info would be very much appreciated, i'm planning to make a trip from DC to Boston at the end of this month and i would like to get this sorted before then. Thank you!
Old May 7, 2015 | 02:35 PM
Could be two things, thermostat sensor : if the coolant is not low or the thermostat hosuing is not leaking. Check for leaks at the thermostat / water pump / and expansion tank first. Check on top of the transmission. Then check the coolant level in the expasion tank.
1. Then go to that sensor. Sometimes they go bad and replace it.
2. If you find you are low on coolant or have a leak the coolant is too low and not reaching the sensor.
3. When you start the car and it warms up do you get warm air when you turn on the Heater ? If no then its points to low coolant => coolant leak.
If you have a leak, get it check asap.
DIY and places to inspect:
https://www.northamericanmotoring.co...8-no-heat.html
Old May 11, 2015 | 07:37 PM
santypnoy4's Avatar
santypnoy4
Thank you ECS, sorry I couldn't reply right away I was moving to a new apt. Anyways I don't see any signs of leaks and my coolant levels are normal, I also get warm air from the heater. This means, most likely the sensor? If I'm going to do that should I just go ahead and replace my thermostat as well?
Old May 12, 2015 | 05:53 AM
No problem,
Insurance if you have not replaced the whole thermostat already and are on the original. Sounds like a bad sensor ( top thermo sensor) if everything else on that check list is ok.
You have the DIY linked above.
Old Jun 29, 2015 | 07:27 PM
santypnoy4's Avatar
santypnoy4
Thanks ECS, i have purchased the new thermostat from you and just got it installed this weekend. It wasn't too bad and the DIY link definitely helped a lot! Everything turned out well and no leaks but i got a different CEL this time.
Its for 2F1A, "Coolant temperature sensor signal circuit or short circuit to positive". That's the code I'm getting from my scanner. Did i have a bad sensor, should i buy a new one and swap it out?
Now my fan would turn on even when the car is not warm and would stay running for a while. Even when i start it for a few seconds the fan would kick in. I have tried to clear the code but it doesnt go away. I also tried disconnecting the battery for a few hours to see if this would reset it but its still there.
Any idea what it could be? thanks for all the help!!!
Old Jun 30, 2015 | 11:34 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
If it comes back right away it sounds like a circuit fault. If it takes a drive cycle before the fault comes back, then it's temp related fault. Make sure there is no coolant inside the plug. Go over the install and make sure you didn't miss plugging something back in. (DIY here). It's possible a sensor failed, but check all of these things first.
-Luccia
888.280.7799 | 6am - 5pm PST
Old Jul 10, 2015 | 05:20 AM
You are welcome. Glad I could help.
Sounds like the top plug that goes to the sensor is damaged , cut or not plugged in all the way. Make sure to plug it in and also check that harness.
rtk90
Aug 29, 2019 09:08 AM
newowner
Sep 15, 2015 07:18 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
Sep 4, 2015 01:32 PM
Sep 4, 2015 01:31 PM
