R56 CAN Engine Coolant Temp Invalid/Random Misfires — Need Help
Old Apr 27, 2015 | 09:09 PM
Yoshiboy's Avatar
Yoshiboy
Hi 2nd Gen Mini Folks,
I have 2009 MCS w/84K on it. The other day everything was fine until the Amber Engine light came on. I went to get a code reader because I've been in a MINI Shop what seems to be every month for the last 6 months.
I'm getting 6 Codes.
P173B CAN Engine Coolant Temperature Invalid
P112B Engine Coolant Temperature Too Low
P0300 Random Midfire Detected
P0304 Cylinder 4 Misfire Detected
P0301 Cylinder 1 Misfire Detected
I replaced the temp sensor to see if that was the problem. But nothing changed. And now the I'm getting even more I errors codes.
Someone please give me some advice as to what to do. I'm at my wits end.
Thanks,
Yoshi
Old Dec 29, 2016 | 01:00 PM
delta86d's Avatar
delta86d
Thanks,
Yoshi
Hello Yoshi,
I have the very same year and model as your car and after replacing the thermostat is also getting the same problems. Where you able to fix the problem? If you were could you please share it with me.
Thnaks in advance and Happy New Year.
Delta86d
Old Dec 29, 2016 | 05:57 PM
MC_Clubman09's Avatar
MC_Clubman09
So here is what I did that gave me issues, and might be yours as well. The connectors are easily mixed up at the top. There's also one toward the back that I missed. I stole these pics and tweaked them a bit. Ignore the red arrows; they are part of the write-up from Pelican.
-thermostat.jpg-thermostat-wire.jpeg-pcv-connector.jpg-oil-pressure-and-temp-sensor.jpg
In my case I switched the PCV and temp sensor connectors; they seem to be almost identical. The one I've labeled 'other connector' (since I have no idea what it is), I seem to have misplaced and will have to go back in and find it. I think I buried it under some tubing. I am getting two codes with the CEL; P0597 and P0598, which I strongly suspect will go away after I find that miscreant connector.
Good luck!
Ray
Kimolaoha
Jul 5, 2023 01:04 PM
Cereall
Sep 5, 2019 06:05 PM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
Chippawaguy
Aug 19, 2015 10:59 AM
tylewis
Aug 18, 2015 06:53 AM
