R57 Check engine light
Old Apr 12, 2015 | 03:23 AM
Miteemini's Avatar
Miteemini
Check engine light
I have a check engine light at 41k. Codes say I have a misfire in 1,3,4. I do not live near a dealer so found a mini specialist who says I need to have the valves cleaned. Total job $773. I also found out this is a problem with the minis. Anyone else have this issue?
Old Apr 15, 2015 | 07:37 AM
If you can DIY its here for the valve / intake cleaning.
https://www.northamericanmotoring.co...-cleaning.html
Also check the HPFP 13517588879 You have the R57 MCS n14 engine so same HPFP.
https://www.northamericanmotoring.co...r-r56-jcw.html
or the spark plugs / coil also I would also check. Since it multiple miss fires it I would point towards HPFP or carbon. You have low miles for Carbon issues but it does happen. When they scope the intake with a video probe , you will know.
Good luck.
Old Apr 15, 2015 | 10:31 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Carbon build up is very common with these vehicles so doing a clean up is a good idea.
Also, possibly attempt to switch your coil packs around. See if the misfires continue or change around as it seems at least one (#2) isn't misfiring. That's a good way to tell if it's bad coil packs, which is common as well.
-Luccia
888.280.7799 | 6am - 5pm PST
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
