R56 What type of tape is safe on the car's paint?
Old Apr 6, 2015 | 08:05 AM
Cngizbleevng's Avatar
Cngizbleevng
I'm going to tape off the sunroof on my wife's car to find out if that's the source of a leak. I'll need to leave it in the rain for a couple days.
Is there any particular kind of tape I should be using so as not to damage the paint? I also want a kind of tape that would be water-resistant to completely seal off the sunroof.
(BTW, it's not the mini, but another car she owns--figured the responses could be potentially helpful here as well)
Old Apr 6, 2015 | 09:44 AM
Fly'n Brick's Avatar
Fly'n Brick
Blue painter's tape. I've used it to mask off the vinyl stripes while running the random orbital for polishing. Just don't leave it for more than a day or two.
Old Apr 6, 2015 | 10:54 AM
+1 blue painter tape, guys like it for Auto X protection from rocks and such.
Old Apr 6, 2015 | 12:37 PM
RB-MINI's Avatar
RB-MINI
Blue painters tape should be safe for the paint, but I'm not sure if it will hold in the rain, or keep the water out of the sunroof jamb/drains.
Old Apr 6, 2015 | 01:07 PM
miniuy's Avatar
miniuy
+1 on blue painter tape and ... maybe duct tape over the blue tape (and ONLY over the blue tape).
Just for 2 or 3 days.
Old Apr 6, 2015 | 01:13 PM
ShipM8's Avatar
ShipM8
Check with an auto glass shop since they regularly tape in replacement windshields. I'd throw down a coat of wax prior to your tape-job.
Old Apr 6, 2015 | 01:35 PM
Laura & Gary's Avatar
Laura & Gary
you could always put down vinyl to get a better seal (can find at most craft stores)
Old Apr 7, 2015 | 07:43 AM
Cngizbleevng
I went in to the local auto parts store and they had green tape they suggested I use. It has the feel of masking tape or painters' tape, and I don't know if there's any real difference.
Old Apr 7, 2015 | 01:34 PM
Fly'n Brick
3M Automotive Performance masking tape? No worries.
Old Apr 7, 2015 | 01:58 PM
Capt_bj's Avatar
Capt_bj
If the green they showed was 3M you might want to review this 3M chart ...
the green is great for masking as it provides a cleaner 'edge' than blue and can be removed 'clean' after much longer
... BUT
It has LESS holding strength (important if you plan to drive with the tape on the car vs. just letting it sit in rain) and a lower temperature resistance (200 vs 250) which can be important if the car will be sitting in the sun and has a dark color roof . . .
I think the green costs more ... but may not be better for your application.
I would not use a plastic tape or duct tape .... I know "masking tape" is safe but dunno about the other stuff
If not 3m tape .... Google Green Masking Tape ..... I got a bunch of articles about comparisons to blue . . .
I'd use Blue 3M .... actually I did in the past for a similar application. After having the windshield replaced on a Honda Element TWICE ... I still got a wind whistle above 50 mph. I used blue masking tape over the seal to identify the exact problem area (and SAFELITE replaced the glass a third time - no extra charge - and used a different gasket material which solved the problem)
MiniJess
Detailing 101
30
Aug 4, 2016 03:43 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
SamtheSham152
R57 :: Cabrio Talk (2009+)
Aug 14, 2015 07:01 PM
ludedude
Aug 10, 2015 07:16 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
