FS:: OBDII Kiwi˛ w/ Analog Input COMPLETE SETUP
Category: Interior
Price: $65
Part fits (you may select multiples): R50, R52, R53, R55, R56, R57, R58, R59, R60
Location (Region): SouthEast
I upgraded to the PLX 52mm Gauge Setup so I no longer need the WiFi Unit.
This will work with both the iPhone and the Android as well as laptops.
I used it with the Dash Command App on my iPhone.
Some information from the PLX site:
Overview:
Kiwi 2 Wifi is a plug and play automotive tool that connects to the onboard diagnostic port (OBDII / CAN). This tool communicates and retrieves information from your car's computer and wirelessly transmits to any iPhone, iPod Touch and iPad. It is compatible with 1996 and later vehicles and installs in seconds. The Kiwi 2 Wifi can efficiently monitor a vehicle's MPG, data log engine parameters, read/reset engine trouble codes and monitor real time engine performance. Simply connect your device to the Kiwi 2 Wifi through a wifi connection, and launch the compatible app of your choice to obtain vital information about your vehicle.
The Kiwi 2 Wifi includes several improvements over the first generation award winning Kiwi 1 Wifi. It now comes with a sleek new design and is 0.25 inches thinner. The cable length has been reduced from 6 feet to 3 feet, making for a cleaner permanent installation. It incorporates an elm327 compatible interface and it works with ISO9141, VPW, PWM, and CAN protocols.
The Kiwi 2 Wifi incorporates a new advanced power saving circuit, designed to shut off power to essential functions of the unit allowing the Kiwi 2 Wifi to be permanently installed in your vehicle without draining your vehicle's battery. After 5 minutes of inactivity, the Kiwi 2 Wifi automatically enters a low power sleep mode. To turn the unit back on, a simple press of the soft switch wakes the device back up.
The Kiwi 2 Wifi includes an 8 pin port on the back designed to be mated with the PLX iMFD Adapter. This allows you to connect high performance aftermarket sensors such as wideband air/fuel ratio, exhaust gas temperature, vacuum/boost, air intake temperature, fluid pressure and fluid temperature and view on your iOS mobile device. This solution is desired for applications where vehicles do not support certain sensors and/or the car's computer does not report them. With the PLX iMFD Adapter attached, the best of both worlds of fully plug and play OBD2 / CAN data as well as high performance aftermarket sensors can be obtained.
Features:
Depending on the application, the following features may be available:
- Check Engine Diagnostics
- Real-time Gauges
- Fuel Efficiency and MPG
- Engine Sensors
- Customizable Dashboard
- Real-time Dyno
- Data Logging
- GPS Track Mapping
- Skid Pad
- Video Recording and Data Overlay
- iMFD Aftermarket Sensor Interface
