:: ECS Tuning :: SPC Camber Plates | ECS SS Brake Lines | Gen 2 LCAB Set | FORGE
Old Apr 1, 2015 | 06:59 AM
R56 MINI Cooper SPC Front Camber Plates
For track-ready cars like the R56 MINI, suspension adjustability yields huge gains in handling characteristics.
SPC Performance Front Adjustable Camber Plates are an excellent investment for the MINI owner looking to dial in a more aggressive front camber and caster specification, keeping the tire contact patch more parallel with the road surface during hard cornering when traction is most needed.
The aluminum plates are coupled with an OE-style bearing within a bonded urethane insulator, allowing for +/- 2 degrees of camber and +/- .75 degrees of caster adjustment.
Dialed-In Performance
Fits:
R56 MINI Cooper S/JCW (2007-2013))
Click HERE for SPC
MINI R58 R59 ECS Exact-Fit Stainless Brake Lines
ECS Exact-Fit stainless reinforced brake lines provide more confident and dependable stopping by maintaining consistent brake pressure, long lasting corrosion resistance, and increased protection from failure.
Even when new, factory style fabric mesh lined rubber hoses are prone to expansion under the pressure of hard braking, whether it be highway panic stops or threshold braking at the track. Our lines are braided with stainless steel mesh, affording expansion resistance. This resistance to expansion creates a firmer pedal, and more direct pedal feel.
Stopping Never Looked So Good
Fits:
R58 MINI Coupe/S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE ECS Brake Lines
R56 R55 R57 R58 R59 Vaico Lower Control Arm Bushings
Is your MINI Cooper making noises over bumps, or does your steering feel loose and less responsive than it once was?
The control arm bushings are a big cause of front suspension problems, and the only remedy is to replace them.
This kit was built by the experts at ECS Tuning, and it includes both lower control arm/wishbone bushings.
Both bushings are already pressed into their brackets, so you won't have to worry about renting or buying the equipment needed to press the bushings in.
Fix your front suspension issues today with this kit from ECS Tuning.
The Best Remedy
Fits:
MINI R56 Cooper /S (2007-2013)
MINI R55 Clubman /S (2008+)
MINI R57 Cooper Convertible /S (2009+)
MINI R58 Coupe' /S (2012+)
MINI R59 Roadster /S (2012+)
Click HERE For Vaico LCAB
MINI R50/R52/R53 Cooper Forge P/S Tank
Are you tired of looking at your old, dirty power steering reservoir in your Mini, and want to replace it with some eye candy?
Or is your power steering reservoir leaking expensive fluid all over the engine compartment?
Forge has the perfect solution with this alloy power steering fluid tank, engineered to be a direct fit and made from machined and polished aluminum - you can forget about fluid leaks from this tank in the future!
Forge Ahead
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper / S / JCW ( 2005-2008 )
R53 MINI Cooper S / JCW ( 2002-2006 )
Click HERE For Forge
MINI R50/R53 Exact-Fit Brake Lines
ECS lines are braided with stainless steel mesh, affording expansion resistance. This resistance to expansion creates a firmer pedal, and more direct pedal feel for your MINI R50/R53.
Fits:
R50 MINI Cooper (2002-4/2003)
R53 MINI Cooper S / JCW (2002-4/2003)
Click HERE For ECS Brake lines
MINI R58/R59 S/JCW Forge Uprated Alloy Intercooler
Drop intake temperatures, boost HP & Torque with the Forge Uprated Alloy Intercooler for your MINI R58/R59 S/JCW.
The formula is simple. However, it's easier said than done.
Leave it to Forge Motorsport to accept the challenge and improve on an already brilliant design. Significant HP gains have been reported due to the substantial drop in intake temperatures. It's safe to say they succeeded.
Additionally, a cooler running engine better resists heat expansion and stress, increasing the longevity of your powerplant.
Stay Cool.
Fits:
R58 MINI Coupé S/JCW (2012+)
R59 MINI Roadster S/JCW (2012+)
Click HERE For Forge Intercooler
MINI R58/R59 JCW N14 Engines Forge Diverter Valve
Stock diverter valves just can't handle performance upgrades. Add a little boost and they get all weak in the knees and blow the diaphragm to pieces. .
Forge knows this. That's why they've engineered boost-hardy diverter valves tough enough to take the pressure without blowing their lids.
These are completely serviceable valves with an aluminum piston and o-ring seal, compared to the easily tearing rubber diaphragm found in the OEM valve.
Forge Ahead!
Fits:
MINI Gen2 S/JCW N14 Engines Forge Diverter Valve
Forge knows this. That's why they've engineered boost-hardy diverter valves for your MINI Gen2 S/JCW N14 engine, tough enough to take the pressure without blowing their lids.
Forge Ahead!
Fits: N14 engines
R56 MINI Cooper S (2007-2010) / JCW (2009-2012)
R55 MINI Clubman S (2008-2010) / JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) / JCW (2009-2012)
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
