R56 Loose part found in oil pan, need help identifying it
Old Mar 28, 2015 | 05:57 PM
Miguel A.'s Avatar
Miguel A.
Hello, Im new to the forum not sure if this is the right place to post it.
Anyway, long story short I recently embarked on a journey to replace a burnt head gasket on a 2008 Mini Cooper Base. so far so good, found that there are a couple of burnt valves and I am taking the head to a shop. I took the oil pan off this morning and found a piece of metal in the sludge. Does anybody know where it is from? I can't seem to find where it came from here is a picture, thanks everyone in advanced for any info!
Attached Thumbnails Loose part found in oil pan, need help identifying it-img_2423.jpg   Loose part found in oil pan, need help identifying it-img_2424.jpg
Old Mar 28, 2015 | 06:28 PM
dhroz's Avatar
dhroz
It s a dowel pin from the cylinder block. It more than likely fell out into the engine when you pulled the head.
Old Mar 28, 2015 | 06:43 PM
Miguel A.'s Avatar
Miguel A.
No, the block dowels are still in place, this piece is smaller than that, and actually I should have mentioned I found this piece in the oil pan BEFORE taking the head off. Thanks for the response though
Old Mar 28, 2015 | 11:32 PM
SPRINTCARS's Avatar
SPRINTCARS
Only place I've seen something that resembled that was a wrist pin. But if it was a wrist pin the pistons and rod would have came apart. And you would have surely known that by some seriously loud noises and bangs.
Old Mar 29, 2015 | 12:01 AM
TBRoye's Avatar
TBRoye
Could it have been left over from the original engine assembly at the factory. If that part would have come from the engine after it was sold something bad would have happend or it would have been noisy. Looks like a dowle of a pin of some kind. I would check the enging carefully before reassembly.
Tom
Old Mar 29, 2015 | 12:37 AM
SPRINTCARS's Avatar
SPRINTCARS
Ive got two photos of a factory wrist pin just to show ya what one looks like.
Wrist pin
Old Mar 29, 2015 | 12:38 AM
SPRINTCARS's Avatar
SPRINTCARS
Another view
Old Mar 29, 2015 | 12:39 AM
SPRINTCARS's Avatar
SPRINTCARS
That part you have looks very familiar. Now im curious as hell.
Old Mar 29, 2015 | 01:34 AM
Drivehard's Avatar
Drivehard
Was the timing chain intact? Looks lie it could be one of the chain links?
Not a wrist pin. Too tiny. Other ideal is some sort of dowel. Missed at assembly
Sent from my iPad using NAMotoring
Old Mar 29, 2015 | 07:31 AM
SPRINTCARS's Avatar
SPRINTCARS
Originally Posted by Drivehard
Was the timing chain intact? Looks lie it could be one of the chain links? Not a wrist pin. Too tiny. Other ideal is some sort of dowel. Missed at assembly Sent from my iPad using NAMotoring
Thats way to big to be a chain link
Old Mar 29, 2015 | 07:43 AM
Drivehard's Avatar
Drivehard
Originally Posted by Miguel A.
Hello, Im new to the forum not sure if this is the right place to post it. Anyway, long story short I recently embarked on a journey to replace a burnt head gasket on a 2008 Mini Cooper Base. so far so good, found that there are a couple of burnt valves and I am taking the head to a shop. I took the oil pan off this morning and found a piece of metal in the sludge. Does anybody know where it is from? I can't seem to find where it came from here is a picture, thanks everyone in advanced for any info!
OP. what are the dimensions of that piece?
Old Apr 9, 2015 | 04:11 PM
SPRINTCARS's Avatar
SPRINTCARS
ever find out where that piece came from ?
Old Apr 9, 2015 | 05:11 PM
neonsteve's Avatar
neonsteve
You should look on realoem.com. It looks like it might be dowel pin part number 11227542759, 8x15. Goes on the end of the crankshaft and crank gear? Or maybe dowel pin 11117581549, 14x20 that looks to go between engine and transmission, but I don't think this could end up in the oil pan.
PS: The part in the OP's photo looks like it has some wear/use so I doubt it was left in there during manufacture.
Old Apr 9, 2015 | 05:26 PM
breyfogle's Avatar
breyfogle
Can't judge how small it is but the first thing I thought of was a roller from a bearing.
Old Apr 10, 2015 | 05:30 AM
I was think timing chain link also. If its really that small, Cant judge by the pic , no reference.
Old Apr 10, 2015 | 07:22 AM
stevie01's Avatar
stevie01
sump find !
that looks like dowel that holds lower crank case to block factory drop off
Old Apr 11, 2015 | 04:05 AM
N2MINI's Avatar
N2MINI
OP hasn't been in here in a couple of weeks. Might be bad news. I'd think if it was part of the timing chain, in order for that to happen wouldn't the pin be in the oil pan as well? and at that point the chain has separated. Based on his pic of it sitting on his laptop looks to be about 1'' tall.
Old Apr 12, 2015 | 09:07 AM
mtechnik2's Avatar
mtechnik2
It looks like the set pin/end stop for the valvetronic motor, did you by any chance just pull the motor out without spinning the Allen key loose on it. If so it more than likely broke off the cylinder head.
Old Apr 12, 2015 | 09:14 AM
mtechnik2's Avatar
mtechnik2
http://i.ytimg.com/vi/SFfY_12q86o/maxresdefault.jpg
It looks like the valvetronic endstop
Old Apr 13, 2015 | 05:18 AM
Hopefully OP comes back.
Old Aug 3, 2015 | 05:56 AM
Austin1o5's Avatar
Austin1o5
Holy crap, well the other day I dropped a lash adjuster down the block on my 2007 Mini Cooper non s. While I had my oil pan off this exact pin dropped right next to my head, it fell as soon as I was moving the oil pump around to remove the windage tray. This is to large to be from a timing chain.
Old Aug 4, 2015 | 10:16 PM
renchjeep's Avatar
renchjeep
Maybe a locator pin for the oil pump or pickup tube? Never had a MINI engine apart (thankfully), but IIRC, there is a locating pin for the oil pump on a small block Chevy V8. WAAAY different animal, I know. Just throwing it out there......
Old Aug 5, 2015 | 03:01 AM
Austin1o5's Avatar
Austin1o5
I went to a mini dealer the other day and spoke to the lead tech, he told me to check the vvt mechanism. aside from that he had no clue what it was..
Old Dec 20, 2016 | 02:19 PM
herbie_53_guy's Avatar
herbie_53_guy
Doing a pan gasket and found not one, but 2 of these pins. Now i really want to know.
Old Dec 20, 2016 | 05:19 PM
oldbrokenwind's Avatar
oldbrokenwind
In the middle of a complete rebuild --- pretty sure the OP found one of the two dowel pins that guides the two block halves together. Can't tell for sure without knowing OD and length, then OEM can be researched. Mine's already back together, so no way is it coming apart to verify.
