FS:: VIP Cold Air Intake Combo
Price: $400
Comes with everything shown-
· Cold air intake: comes with a K&N high flow air filter. Brackets, silicone tubes, clamps and all hardware needed to let your Countryman S breathe right. Laser cut and powder coated mounting bracket with removable top cover to access the filter for cleaning. Estimated 10HP gain @ 4650 rpms
· Strut Bar: front strut bar and tower plate combo for the R60 Countryman S. The bar clears your stock S intake. The end plates are laser cut from steel then tig welded to perfection. The end plates are powder coated in Texture black and the round bar comes in Texture black.
· Turbo Heat Shield: This will cover the O.E.M. turbo heat shield to dress up the hammer job of the factory part and also keep the heat under control from the turbo. Laser cut from 300 series stainless steel and then run through the grainer to add a nice finished look. Comes with CNC machined mounting hardware and all stainless steel bolts.
chrisx18240
26
Mar 16, 2022 09:56 AM
