R50/53 R50 rear license plate mount
Old Mar 23, 2015 | 11:50 AM
mattymini's Avatar
mattymini
Anyone know where I can get one? It seems the mounts have "internal" nuts to thread into. My upper right one just spins and spins when attempting to remove the bolt holding the plate on. Was able to finally get it off, but would like to replace the mount with something new. Will any "universal mounts" work on a generation 1 R50?
Thanks!
Old Mar 23, 2015 | 12:16 PM
Kahnfucious's Avatar
Kahnfucious
Originally Posted by mattymini
Anyone know where I can get one? It seems the mounts have "internal" nuts to thread into. My upper right one just spins and spins when attempting to remove the bolt holding the plate on. Was able to finally get it off, but would like to replace the mount with something new. Will any "universal mounts" work on a generation 1 R50? Thanks!
About $30 on eBay - not sure that it's OEM but I got mine there. Fits fine.
Old Mar 23, 2015 | 12:23 PM
You can get a new mount and when you install the new screws put a little anti-seize on them a bit. Then when you take it off again the nut will not seize then spin.
If you have an old one you can sometimes get it with a very long needle noise pliers and hold the square nut. They undo the screw.
Some of the aftermarket ones I have seen would have to match the holes perfect and then no bang up against the trunk.
http://www.ecstuning.com/Search/SiteSearch/51188238061/ES88492/
and
Screw x 4 07119906254
http://www.ecstuning.com/Search/SiteSearch/07119906254/ES2676928/
nismo4life
Nov 4, 2015 09:18 PM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
