R57 Retofit connect/enhanced bluetooth
Old Mar 22, 2015 | 09:55 AM
Gilberto Rodriguez's Avatar
Gilberto Rodriguez
Hello guys!!
My apologies if this has been asked before.
Im about to pull the trigger on a cooper s cabrio from 2009.
The car is in great condition and it has all the extras. I love it!!
The only thing that bothers me is the lack of audio over bluetooth. i hate cables
The car has bluetooth, a center console usb and aux and sat nav.
The last seven digits of the vin are tx78531 and the radio\bluetooth model is 9229740.
My question is. Can enhanced bluetooth be retrofitted\coded somehow? I dont really care about connected, but the lack of audio over bluetooth would make me think twice, which sucks as im getting a great deal.
have a great day you all and please help me out or point me in the right direction
best regards,
Gilberto
Old Mar 25, 2015 | 05:00 AM
Adam1724's Avatar
Adam1724
You can choose to have audio playback using Bluetooth or usb/aux. I've used both and did not notice any sound difference. I prefer the sub/aux so my phone will charge too.
Old Mar 26, 2015 | 01:36 PM
Gilberto Rodriguez
Hey man!
Thanks for the answer!
Unfortunately the car does not allow to play audio over bluetooth. Works only for the phone (Calls and so on)
So what I would be interested in doing is retrofiting enhanced bluetooth or adding a third party adapter that would let me play audio over bluetooth.
Any suggestions or comments?
Thanks!
Old Mar 26, 2015 | 02:43 PM
Adam1724's Avatar
Adam1724
Yes it does you just have to un select the sub/aux port and select the Bluetooth box.
Old Mar 27, 2015 | 01:30 AM
Gilberto Rodriguez
Hey man!
Thanks again!
I'm afraid I am a little confused. I was under the impression that to be able to play Audio over Bluetooth an extra option was to be installed when te car was order.
The "enhanced bluetooth"
Where can I unselect the usb/aux bow?
Thanks!
Old Mar 29, 2015 | 05:53 AM
americo11's Avatar
americo11
If you have don't have bluetooth option you can buy a cheap MPOW ($16) from amazon and that plugs into your aux in I also purchased a Pac ground isolator which connects between the bluetooth module and the aux (it basically filters out noise)
so as not to get any whir noise from engine etc...option ..press the audio button under speedo...then scroll to aux press button to keep it on aux next hit the little button on the mpow and it makes a sound letting you know you are connected next you go into your phones bluetooth settings and connect to the mpow ..done....you can now play your music bluetooth through your radio.....you can not scroll up or down using steering wheel buttons, that you have to do with phone itself. So for the mare price of say $30 you have bluetooth streaming from your phone and the phone music will still pause when a call comes through and continue after call has stopped.
Old Mar 29, 2015 | 09:36 AM
Gilberto Rodriguez
Cool!
Thanks a lot man!
Its by far the best option I have read so far. I really appreciate.
Still, do you know if its possible to code/retrofit enhanced bluetooth?
Thanks!
Old Mar 29, 2015 | 10:17 AM
americo11's Avatar
americo11
Sorry I don't but maybe some one who is more knowledgeable about the subject will pop on....In all honesty the way I stream my music is fine for me I used the same method when i had my Boxster. I hate having wires everywhere so that is why I opted this method.
Old Mar 29, 2015 | 10:25 AM
Gilberto Rodriguez
Yeah! I hate cables too. Thats why Ill probably follow your advice.
The only reason why im interested in getting the enhanced bluetooth coded is having the hability to use the wheel buttons to skip my music
Thanks!
Old Mar 29, 2015 | 04:00 PM
rkw's Avatar
rkw
Not for a 2009 model. MINI Connected requires the newer electronics that were upgraded in 2011 model year. MINI Connected is required for bluetooth audio streaming.
Old Mar 30, 2015 | 07:46 AM
wkearney99's Avatar
wkearney99
What about a 2014 R57, without Connected?
It has the usb/aux input option but, unfortunately, the USB socket does not deliver enough amperage to charge the phone (Moto X). Nor do I want to get into using an audio cable, as that clutters up/complicates putting the phone into the mount. I have a charger that has a bluetooth receiver and an aux-output. That, also, does not have enough amperage to charge the phone. This certainly has a lot to do with the phone, but I'd love to find a proper way to use bluetooth media playback AND charge it.
It seems supremely short-sighted to have support for Bluetooth phone but not media playback.
Old Mar 30, 2015 | 08:24 AM
rkw's Avatar
rkw
Nope. MINI/BMW have a way of packaging things so that customers buy expensive options they didn't want.
Old Apr 3, 2015 | 10:08 AM
thesilkiest's Avatar
thesilkiest
I have one on order...
It's supposed to be seamless and sound is apparently excellent.
I will post back here when it arrives.
Patec® USB Bluetooth Wireless Audio Music Receiver Adapter w/ 3.5mm Stereo Output for Headphones Portable Speakers Home and Car Stereo Systems - Black: Amazon.ca: Cell Phones & Accessories Patec® USB Bluetooth Wireless Audio Music Receiver Adapter w/ 3.5mm Stereo Output for Headphones Portable Speakers Home and Car Stereo Systems - Black: Amazon.ca: Cell Phones & Accessories
BTW have your MINI checked out by a 3rd party. We bought our 2010 from a dealer and then had our mechanic look at it. A little bit backwards. It was lower risk because it was a Mini Dealership. They had documented all the inspection details and it had an extended warranty on a used vehicle. But when we spoke with our mechanic on her first checkup they showed some concern as some of the older MINIS have issues. Ours turned out OK but...
Old Apr 3, 2015 | 02:21 PM
laforze's Avatar
laforze
Kinivo and call it a day. It's 35 bux, but it also has a built in usb port in the lighter adapter as well as a control unit that is mountable and easy to hide the wires.
Amazon.com: Kinivo BTC450 Bluetooth Hands-Free Car Kit for Cars with Aux Input Jack (3.5 mm) - supports aptX: Cell Phones & Accessories Amazon.com: Kinivo BTC450 Bluetooth Hands-Free Car Kit for Cars with Aux Input Jack (3.5 mm) - supports aptX: Cell Phones & Accessories
navybsn
Oct 5, 2018 04:42 PM
gar56
Nov 15, 2016 06:41 AM
Chimera
Sep 30, 2015 02:53 PM
krohm
Sep 28, 2015 12:16 PM
