FS:: NM Engineering Strut Brace
Old Mar 20, 2015 | 07:53 AM
LFCMCS's Avatar
LFCMCS
Category: Suspension
Price: $1
Location (Region): Midwestern
For Sale - NM Engineering strut brace with mounting long reach nuts. Has had a few very minor scratches (1/8th of and inch and once scratch on the underside of the bar - 1 inch) that have been corrected with touch up paint - nothing noticeable once installed on the car. Shoot me an offer (these sell for over $300 + shipping pretty much everywhere - so please, no low ball offers)
NM Engineering’s Upper Tie-Bar is designed to reinforce the already stellar MINI Cooper chassis. Installation reduces fore and aft, as well as side-to-side chassis flex during spirited driving, which helps to eliminate unwanted geometry/alignment change. This results in better steering response and better handling.
Attention to detail and performance are NM Engineering’s forte and this part does not disappoint. The 6061-T6 aluminum mounting pads will eliminate strut tower “mushrooming” be reinforcing the upper mount and is attached to mounts studs with shouldered long-reach nuts to make sure that the bar and front suspension is secured by more than just a few threads. In addition, when you look at the underside of the pads, you will notice two machined pocket that accommodate the upper strut bearing locator pin on either side while concealing it from view. Finally, the simplest, yet most overlooked feature may be the twin mounting bolts on each side that attach the bar to the mounting pads. Most others use a single bolt to secure each side of the bar to the mounting pads. The problem with that, is no matter how tight you cinch that bolt, the bar can still pivot at that point rendering them ineffective against chassis flex.
Attached Thumbnails NM Engineering Strut Brace-img_1112.jpg   NM Engineering Strut Brace-img_1113.jpg   NM Engineering Strut Brace-img_1115.jpg   NM Engineering Strut Brace-img_1114.jpg
Old Mar 20, 2015 | 10:12 AM
santypnoy4's Avatar
santypnoy4
interested, do you know if they will fit with K&N intake?
Old Mar 20, 2015 | 12:11 PM
LFCMCS's Avatar
LFCMCS
You will need to check with NM Engineering.
Old Mar 20, 2015 | 06:08 PM
ASuman's Avatar
ASuman
I'll take for $150.00 let me know as I can pay now
Old Mar 21, 2015 | 05:05 AM
LFCMCS's Avatar
LFCMCS
Send me a PM and I will respond by this evening. Got to go out during the day.
Old Mar 22, 2015 | 02:51 PM
LFCMCS's Avatar
LFCMCS
Old Mar 22, 2015 | 05:48 PM
ASuman's Avatar
ASuman
Just PM'd you. Thanks
Old Mar 22, 2015 | 06:12 PM
LFCMCS's Avatar
LFCMCS
Just responded to your PM.
Old Mar 23, 2015 | 01:24 PM
LFCMCS's Avatar
LFCMCS
Old Mar 23, 2015 | 07:37 PM
LFCMCS's Avatar
LFCMCS
Sold!
W0TM8
Dec 19, 2019 07:50 AM
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
Dec 23, 2015 10:36 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
