JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW R56 MINI JCW GP 2 ECS Tuning Exact-Fit Brake Lines
Old Mar 12, 2015 | 11:48 AM
If you spend time and money renewing your brake hardware and linings, use this time to upgrade to the stellar ECS Tuning Exact-Fit brake hoses, and do the job right.
The premium brake hoses are significantly stronger, more reliable, and better protected than those supplied from the factory.
Shielded in stainless steel mesh reinforcement, and coated with bright red vinyl for added protection, the lines look as good as they perform.
Available by the axle for front or rear, or as a complete vehicle set.
Premium Grade. MINI Worthy
Fits:
R56 MINI Cooper JCW GP2 (2013)
Click HERE for JCW GP2
Old Mar 13, 2015 | 03:13 PM
akng's Avatar
akng
Wow, so seems like this is the first Stainless Steels Brake Lines Kit for GP2. Finally!!!
Old Mar 13, 2015 | 10:32 PM
robbo mcs's Avatar
robbo mcs
I put a JCw kit on my GP and they fitted fine. Not sure what is different?
Old Mar 14, 2015 | 09:51 AM
akng's Avatar
akng
Which JCW kit are you talking about? The Goodridge kit for all R56?
Old Mar 15, 2015 | 01:54 AM
robbo mcs's Avatar
robbo mcs
I used the HEL R56 LCI JCW lines.
first of all I had them on a JCW with the brembo 4 pots. I swapped the 4 pots to GP2 calipers and the lines fitted fine.
Then I bought another set and put them straight on a GP2 and they fitted fine.
http://www.helperformance.com.au/hel...per-s-jcw.html
I also have used the Goodridge kit on another GP2, but not sure if they fitted straight up or needed adjusting.
Maybe ECS tuning can chip in a let us know exactly what the difference is? Maybe slightly different length lines from JCW?
Old Mar 16, 2015 | 04:51 AM
Thanks your welcome.
Mostly a different length and they have a extra sleeve protection. These follow the dimensions of the Factory GP2 brake lines on the front, hence Exact Fit. The rears are shared from the Cooper, Cooper S, and JCW.
Old Mar 16, 2015 | 03:09 PM
signcarver's Avatar
signcarver
Can i justify the cost?
@ECSTuning - since i don't track or autocross are these overkill? Will i really be able to tell the difference in the pedal feel?
Thanks,
Steve
Last edited by signcarver; Mar 16, 2015 at 03:13 PM. Reason: added question mark, changed title of post
Old Mar 16, 2015 | 03:45 PM
cerenkov's Avatar
cerenkov
Originally Posted by signcarver
@ECSTuning - since i don't track or autocross are these overkill? Will i really be able to tell the difference in the pedal feel? Thanks, Steve
Have you ever felt your brakes fade or feel squishy during your current driving style? If not then they are probably overkill. They do look really cool though!
Old Mar 16, 2015 | 08:08 PM
signcarver's Avatar
signcarver
Thanks cerenkov!
marendt428
Nov 14, 2015 10:03 AM
StealthR53
Aug 8, 2015 10:59 AM
marendt428
Aug 8, 2015 04:44 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
