:: ECS Tuning :: R55 JCW Aero Kit SALE / Forge N18 Valve \ R60 R61 Xenon Upgrade Kit
Old Feb 17, 2015 | 12:13 PM
MINI R55 Clubman S/JCW Primed Aero II Body Kits
Achieve the highly sought-after performance styling of the MINI JCW in stunning fashion.
Complete John Cooper Works Body Kits that include a front bumper with trim, rear bumper with trim, and side rocker panels/side skirts with trim, are now available for the MINI R55 Clubman S/JCW.
JCW Aero II kits contain the Brake Duct Cooling Package and the more aggressive lower front lip. Aero II packages also include all hardware for a thorough, factory-quality installation.
The Works
Fits:
R55 MINI Clubman S (2008-2010)
R55 MINI Clubman JCW (2009-2010)
Click HERE for body kit
MINI R55 R56 R57 N18 Forge Diverter Valve Upgrade
Stock diverter valves just can't handle performance upgrades. Add a little boost and they get all weak in the knees and go to pieces.
Forge knows this. That's why they've engineered boost-hardy blow off and diverter valves tough enough to take the pressure without blowing their lids.
If an ECU upgrade or other engine aspiration upgrade has significantly altered your manifold boost pressure, or if you're looking to stave off future diverter valve failures, the Forge kit is the wisest solution.
Forge has even included an install PDF on a flash drive to make installation simple.
Forge Ahead.
Fits: N18 engines
R56 MINI Cooper S (2011+)
R55 MINI Cooper Clubman S (2011+)
R57 MINI Cooper S Convertible (2011+)
Click HERE for FORGE kit
MINI R58/R59 Genuine Xenon Headlight Kit
The headlight design of the MINI Cooper defines the car's character more so than any other feature.
MINI is now offering stunning Bi-Xenon headlights in Titanium-Gray housings for the MINI R58/R59.
The genuine MINI kit includes left and right side headlights, and retains the factory clear turn signals.
NOTE: Additional coding will need to be done by a MINI dealership for strobe light elimination on startup.
A Clear Improvement
Fits:
R58 MINI Coupe /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
*Vehicle will need programmed by dealership to activate headlights after install
Click HERE For the Xenon Upgrade Kit
B]MINI R58 R59 N18 Forge Diverter Valve Upgrade[/B]
Forge Ahead.
Fits: N18 engines
R58 MINI Coupe' S (2012+)
R59 MINI Roadster S (2012+)
Click HERE For the Forge kit
MINI GEN 2 JCW N18 Forge Diverter Valve Upgrade
Forge Ahead.
Fits: N18 engines
R56 MINI Cooper JCW (2013+)
R55 MINI Cooper Clubman JCW (2013+)
R57 MINI Cooper Convertible JCW (2013+)
R58 MINI Coupe' JCW (2013+)
R59 MINI Roadster JCW (2013+)
Click HERE for Forge kits
MINI R55 Clubman JCW Aero Kit
ECS presents truly stunning, authentic performance styling from the most hallowed MINI tuner on earth with the John Cooper Works MINI Cooper Aero Kit.
All of this Genuine JCW kit - at an unprecedented value.
Primed kits for the MINI R55 Clubman Base include a front bumper with trim, rear bumper with trim, and side rocker panel/side skirts with trim - completely transforming the impression of your car while retaining the reserved design aesthetic characteristic of all genuine MINI products.
Includes all install hardware in the kit. For vehicles with PDC.
The Works
Fits:
R55 MINI Clubman Base* (2008-2010)
*For vehicles with Parking Distance Control
Click HERE for JCW Aero kit
__________________________________________________ ___________-__
MINI R52 R53 S/JCW Thermostat Replacement Kit
Prevent cooling issues before they begin with an ECS Tuning Thermostat Replacement Kit.
The experts at ECS have identified all of the common parts that fail on a MINI and have included them all in one convenient kit.
If your MINI has high miles or has an unreliable thermostat, replace all the critical components at the same time for added assurance.
Hot or Cold?
Fits:
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible S / JCW (2005-2008)
Click HERE for thermo kit
MINI R60/R61 Genuine Xenon Headlight Kit
MINI is now offering stunning Bi-Xenon headlights for the MINI Countryman and Paceman.
A Clear Improvement
Fits:
R60 MINI Countryman /S/SX/JCW (2011+)
R61 MINI Paceman /S/SX/JCW (2013+)
*Vehicle will need programmed by dealership to activate headlights after install.
Click HERE for Xenon Upgrade Kit
R57 MINI Cooper S Intercooler Resonator Delete Hose
MINI chose to fit a restrictive resonator to the factory intercooler hoses on the R57 Cooper S/JCW. The intention was to reduce engine noise and the recognizable "whoosh" intake sound.
Forge has designed a silicone replacement, freeing up horsepower and torque while better resisting heat and chemical degradation.
The Intercooler Resonator Delete Hose comes in three colors, adding an extra aesthetic dimension to your engine bay.
Smoother interior surfaces enhance airflow, while the silicone material better withstands extreme temperature and pressure.
Forge Ahead
Fits:
R57 MINI Cooper S / JCW Convertible (2009+)
Click HERE for Forge silicone
R55 MINI Clubman S Intercooler Resonator Delete Hose
MINI chose to fit a restrictive resonator to the factory intercooler hoses on the R55 Clubman S/JCW. The intention was to reduce engine noise and the recognizable "whoosh" intake sound.
Forge Ahead
Fits:
R55 MINI Clubman S / JCW (2008+)
Click HERE for Forge Silicone
Jan 4, 2019 12:51 PM
Dec 23, 2015 10:36 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
