Drivetrain what aftermarket gauge most closely resembles stock?
Old Jul 19, 2004 | 06:49 PM
sonichris's Avatar
sonichris
i'm looking for boost and IAT gauges that most closely resemble the stock gauges. the silver face is not really important (white would be fine), but i would like to have orange backlit numbers at night, and an orange needle. i've looked at plenty of gauges (autometer, VDO, etc), but i can't find any. the autometer gauges that come with the kits (ultralite?) are the closest i've found to stock, but i don't think the numbers light up.... anyone know?
Old Jul 19, 2004 | 07:05 PM
maxmini's Avatar
maxmini
Autometer Ultra Lite series which is the same as BMP uses for their aux boost and oil temp gage. I also used them down below for aux volt meter and real water temp gage.
Old Jul 19, 2004 | 07:21 PM
silver-mini-s's Avatar
silver-mini-s
I like the ones that replace the air vents that luminate the same amber color as stock. I will try to find you the link...
Old Jul 19, 2004 | 07:50 PM
sonichris's Avatar
sonichris
these are my second choice. they do have the same color lighting, but not the backlit numbers.
Old Jul 19, 2004 | 09:42 PM
silver-mini-s
This is the link i was talking about. http://www.coolnewamerica.com/produc...ils.asp?id=234
Because they only sell them as a set I was going to purchase 2 boost gauges for my brother and I. I dont care about losing 1 vent hole...
Old Jul 19, 2004 | 09:45 PM
silver-mini-s
The link above is the distributer for the Cool New...Here is the link for the UK site.
http://www.coolnew.co.uk
Old Jul 19, 2004 | 10:21 PM
pocketrocketowner's Avatar
pocketrocketowner
Cool-Silver-S:
Reading your specs, I think i will avoid meeting you in dark alleys......
coolnew should give you thanks....they just got themselves a sale......
Old Jul 20, 2004 | 07:51 AM
Thameth's Avatar
Thameth
The cool new gauges are ummm kool, but i wish they would have made them half an inch smaller so you can still get air out of the vents from the outer ring of the vent, that would have been very very trick!
Do you have to run and tap your own sensors or does it connect to the cars computer?
Old Jul 20, 2004 | 09:06 AM
Hubert's Avatar
Hubert
Defi now makes gauges with amber backlight too.
Old Jul 20, 2004 | 07:46 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Old Jul 20, 2004 | 08:15 PM
Samtrak's Avatar
Samtrak
ded sexy
from www.promini.com
Old Jul 20, 2004 | 08:32 PM
sonichris's Avatar
sonichris
thanks for the info. i really like the defi gauges, especially the link series, but they are quite expensive. i still have yet to see any that light up through the numbers at night like our stock gauges. i have seen some that light the numbers up a different color, but they have black faces instead of white (VDO vision series?). if i could find some with white or silver faces, i could disassemble them and change the LEDs. and although those digital gauges look like they belong there under the A/C panel, i prefer a sweeping needle rather than a digital numerical readout.
Old Jul 21, 2004 | 05:59 AM
USAMINICOOPER's Avatar
USAMINICOOPER
silver-mini-s or anyone else.
I really like those gauges from Coolnew.com
Has anyone istalled these?
Do the rotate?
Does aircondtioner airflow cause a whistle or other problems?
Can you get chrome rings for these gauges to match the rest.
Old Jul 22, 2004 | 05:10 PM
sonichris's Avatar
sonichris
hubert was right!!
check this out:
night:
day:
problem solved!! defi d-gauges match the mini's instrument lighting almost perfectly. why don't any of the aftermarket mini dealers carry these?
check these links:
http://www.defi-shop.com/product/dg/dg_type.html
http://www.defi-shop.com/product/dg/dg_top.html
thanks hubert!
Old Jul 22, 2004 | 06:34 PM
Fidge's Avatar
Fidge
Originally Posted by drdrumanbass
ded sexy
In the picture above, why isn't the line at number 7 and 8 on the Tach lit up like the other numbers? Is this how all the mini Tach's are ?
Old Jul 22, 2004 | 07:33 PM
sonichris's Avatar
sonichris
this is what happens when you turn the lights on with the key off. when you turn the ignition on the redline lights up (all the lines from 6750 to 8000).
Old Jul 23, 2004 | 08:40 AM
Hubert's Avatar
Hubert
Sonichris,
It's my pleasure to help. Please keep us posted if you do install these gauges :smile:
ltjpunk7
Sep 6, 2015 07:32 AM
David.R53
Sep 1, 2015 06:49 PM
Tylerlanger1
Aug 21, 2015 03:03 PM
Emnotek
Aug 13, 2015 05:47 PM
