Cooper tires
Old Jul 17, 2004 | 06:48 AM
mountainrider's Avatar
mountainrider
Cooper tires
I looked on the tire rack and could not find any.I use Avon tires on my bike which is the same company but made in the UK.Has anyone used either of these?The Cooper Zeon 2XS and the ZPT.
https://www.tiresavings.com/tireShop...n=findCombined
Old Jul 17, 2004 | 06:24 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
[QUOTE=mountainrider]I looked on the tire rack and could not find any.I use Avon tires on my bike which is the same company but made in the UK.Has anyone used either of these?The Cooper Zeon 2XS and the ZPT.
https://www.tiresavings.com/tireShop.php?action=findCombined[/QUOTE]
If you have the MINI cooper then you have either
15x5.5" rims and 175/65-15 tires load rating 84 outer diam about 24.3"
or 16x6.5" rims and 195/55-16 tires load rating 87 outer diam about 24.4"
But the normal selection of tires is rather limited so you can look into other sizes but try to keep the outer diameter of the tire to within 3% more or less than the original. Also watch that the load rating is close or more than the stock rating.
For Avon M500 tires at tirerack.com (talk to alex@tirerack.com)
http://www.tirerack.com/tires/tires....odel=Tech+M500
Some choices-
195/55-15 WR rated $73 each 23.5" outer diameter about 84 load rating
205/50-15 WR rated $77 each 23.2" outer diameter about 86 load rating
205/50-16 WR rated $87 each 24.1" outer diameter about 87 load rating
reverse01134
Jan 16, 2017 06:37 AM
Mini'mon
Aug 16, 2015 04:15 PM
nomar116
Aug 9, 2015 09:42 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
