:: ECS Tuning :: H&R Street Coilover R57 : JCW Pipercross : R60/R61 ECS Geomet Rotor
Old Jan 26, 2015 | 12:19 PM
MINI R57 Convertible H&R Coilovers
This H&R Street Performance Coilovers will lower your MINI and give it the performance characteristics needed for daily driving and for the track.
They offer handling and control without feeling every single bump on the road. Manufactured of high grade steel spring and struts which are built to last.
To upgrade your stock suspension and improve your ride quality. A little more aggressive then sport cup kit.
Lowering average 0.75"-1.75" Front / 0.60"-1.75" Rear.
Fits:
R57 MINI Cooper Convertible / S (2009+)
Click HERE for Coilover Kit
MINI R53 Cooper S/JCW Pipercross Performance Air Filter
All engine performance starts with air. Gobs of air, filtered to protect internal engine surfaces from abrasion. That's why European motorsport racing teams have relied on Pipercross Performance Air Filters for a quarter century.
Their unique filter media reduces the pressure drop at the filter while maintaining high filtration efficiency--the ultimate goal of any filter design. Now you can add the benefits of this premium filter to your car with our new and growing line of Pipercross filters.
Washable and reusable, a Pipercross may be the last filter you buy for your car.
Fits MINI:
R53 MINI Cooper S / JCW (2002-2006)*
*JCW Tuning Kit Airbox
Click HERE for Pipercross
R60 R61 MINI Countryman & Paceman GEOMET® Coated Rotors
GEOMET® is a special coating containing metal oxides, zinc, and aluminum flakes, sprayed over the entire rotor surface to ensure complete coverage, and baked on at 600 degrees to form a durable and attractive silver-gray finish that fights rust far better than paints or other conventional coatings.
Slotted or drilled and slotted, you can expect your new GEOMET rotors to outperform and outlast stock rotors, and look great behind your alloy wheels.
Stopping Never Looked So Good
Fits:
R60 MINI Countryman S (2011+)
R60 MINI Countryman SX (ALL4) (2011+)
R61 MINI Paceman S (2013+)
R61 MINI Paceman SX(All4) (2013+)
Click HERE For the ECS Geomets
B]R60 R61 MINI (NON S / SX ) GEOMET® Coated Rotors[/B]
Fits:
R60 MINI Countryman Base (2011+)
R61 MINI Paceman Base (2013+)
Gen 2 R56 Trunk Release Kit
Are you having trouble getting into your trunk?
ECS Tuning has the solution with this Trunk Release Kit, which includes the trunk lid with internals (available in both Primer and Chrome), and the lock mechanism. This kit will allow you to fix the rear hatch button grip with an easy, all-in-one kit.
Available in both Primer and Chrome, if necessary the primed handle can be replaced by your painted handle already on your vehicle.
Fits:
R56 MINI Cooper Hardtop 2007+
Click HERE for kits
MINI R56 N12 Pierburg Vacuum Pump
If your MINI’s brakes are starting too feel softer, or if stopping isn't as precise and powerful as it used to be, the problem may very well be your vacuum pump.
This vacuum pump assists the power braking system in providing ample braking pressure. Located on the driver side of the cylinder head.
ECS now offers a Vacuum Pump from Pierburg for your R56 N12-powered Cooper, remedying this performance-robbing braking issue and repairs a rattling or failed unit.
Fits: MINI
R56 Cooper (2007-2010)
*N12 engines
Click HERE for Vacuum pump
__________________________________________________ ___________-__
MINI R55 N12 Pierburg Vacuum Pump
ECS now offers a Vacuum Pump from Pierburg for your R55 N12-powered Cooper, remedying this performance-robbing braking issue and repairs a rattling or failed unit.
Get Pumped
Fits:
R55 MINI Clubman Base (2008-2010)
*N12 engines
Click HERE for vacuum pump
MINI R57 N12 Pierburg Vacuum Pump
ECS now offers a Vacuum Pump from Pierburg for your R57 N12-powered Cooper, remedying this performance-robbing braking issue and repairs a rattling or failed unit.
Get Pumped
Fits:
R57 MINI Cooper Convertible Base (2009-2010)
*N12 engines
Click HERE for Vacuum Pumps
MINI R50 R53 Trunk Release Kit
ECS Tuning has the solution with this Trunk Release Kit, which includes the trunk lid with internals (available in Black, Primed and Chrome), and the lock mechanism. This kit will allow you to fix the rear hatch button grip with an easy, all-in-one kit.
Available in Black, Polished, and Chrome!
Fits:
R50 MINI Cooper (2002-2006)
Click HERE for trunk grip kits
MINI R52 Trunk Lid Grip
ECS Tuning has the solution with this Trunk Lid Grip which includes the trunk lid with internals (available in Black, Primed and Chrome), and the lock mechanism. This kit will allow you to fix the rear hatch button grip with an easy, all-in-one kit.
Available in both Black. Primed and Chrome, if necessary the primed handle can be replaced by your painted handle already on your vehicle.
Fix that trunk.
Fits:
R52 MINI Cooper Convertible (2005-2008)
R52 MINI Cooper Convertible S / JCW (2005-2008)
Click HERE for trunk grips
Jan 4, 2019 12:51 PM
Aug 13, 2015 12:47 PM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:37 PM
Aug 11, 2015 11:58 AM
