Electrical Wiring aftermarket Daytime Running Lights
Old Jan 26, 2015 | 11:38 AM
jeffrcarlson's Avatar
jeffrcarlson
All,
I'm installing an aftermarket LED Daytime Running Light kit in my 2014 Mini Countryman S All4.
This is the kit (though I bought it from a different seller): http://www.ebay.com/itm/Exact-Fit-5-LED-High-Power-LED-Daytime-Running-Lights-For-MINI-Cooper-Countryman-/131276688582?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e90b34cc6&vxp=mtr
I'm wondering if anyone can recommend a good place to tap into a 12v source to power the DRL relay (it only requires 5 amps)?
I would prefer:
1. A source that only comes on when the car is in Drive (or not in Park)
2. OR, failing that, a source that is only on when the engine is running
3. OR, failing that, a source that is on with the ignition
I have considered using an Add-A-Circuit kit (
Amazon.com: ATO ATC Add-A-Circuit KIT. This KIT includes ATO ATC Add A Fuse (same function as Littelfuse FHA200BP ATO Add-A-Circuit Kit) and 6 ATO ATC fuses (3A, 5A, 7.5A, 10A, 15A, 20A): Automotive Amazon.com: ATO ATC Add-A-Circuit KIT. This KIT includes ATO ATC Add A Fuse (same function as Littelfuse FHA200BP ATO Add-A-Circuit Kit) and 6 ATO ATC fuses (3A, 5A, 7.5A, 10A, 15A, 20A): Automotive
) to tap into a fuse location.
But, I am unsure what fuse would be good to use.
I've checked other postings about this issue, but haven't found a good concise answer.
Thanks!
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
kitty90034
Navigation and Audio
Aug 25, 2015 12:47 PM
JHolland
Aug 13, 2015 10:47 PM
