WMW Turbo Wrap in Stock
Way Motor Works has a fresh stock of our famous WMW Turbo Wrap Heat Shields in stock. This is different from all the other heat shields you see out there as it is a special made exact turbo housing shaped of silica ceramic to hold the heat in the exhaust and keep it flowing. This wrap is used under the stock metal heat shield so you maintain the stock look and the functionality of the OEM heat shield.
In Stock and Ready to order
http://www.waymotorworks.com/wmw-turbo-heat-shield.html
Drivetrain removing heat shields for turbo cat ?
rckrzy1
Aug 11, 2015 06:06 PM
jrezzo
Aug 9, 2015 10:32 PM
