Suspension Caliper paints?
Old Jan 13, 2015 | 09:53 PM
Tristankix's Avatar
Tristankix
Caliper paints?
Wanting to paint my calipers red. Was told to buy caliper paint or also get red Revlon or mary kay nail polish from target. Wondering what will last the longest and look the nicest on my R53 also how should I clean my calipers before painting?
Old Jan 14, 2015 | 05:00 AM
spiney's Avatar
spiney
Just get this:
Amazon.com: G2 High Temperature Brake Caliper Paint System Set Blue G2162: Automotive Amazon.com: G2 High Temperature Brake Caliper Paint System Set Blue G2162: Automotive
Lots of colors, really easy to apply, great finish. Comes with cleaning fluid. instructions, and will do at least two or three coats on all four calipers. Did mine last year.
Old Jan 14, 2015 | 05:10 AM
Saltysalt's Avatar
Saltysalt
I second the g2, they have great reviews and great looks. I would definently get something meant for calipers, since they create so much heat. not all paint is created the same and will flake under extreme heat
Old Jan 14, 2015 | 08:18 AM
Tristankix's Avatar
Tristankix
Thanks for the info!! Will order that and paint it when it's here!
Old Jan 14, 2015 | 08:52 AM
spiney's Avatar
spiney
Good choice, post a pic or two when you have it done.
I just bought a couple of small brass wire/stiff plastic brushes from the hardware store for a couple of bucks so I could get all of the ground-in junk off the calipers. You can paint with the calipers on the car (I did) but there will be a couple of places that you can't get to, but they won't show when you have your wheels on anyway. One day I'll do a full calipers-off job, but it looks great even without.
Old Jan 14, 2015 | 09:00 AM
Tristankix's Avatar
Tristankix
I heard nail polish remover will clean the calipers really well should I just do that?
Old Jan 14, 2015 | 09:20 AM
bavmotors's Avatar
bavmotors
Just painted mine, used a couple different paints before. I like the dupli color and I cleaned them with Crc brake cleaner, however I took mine off to spray them. Make sure you use a high temp clear coat also.
Old Jan 14, 2015 | 09:22 AM
Saltysalt's Avatar
Saltysalt
nail polish remover is primarily acetone, brake clean which I would suggest has acetone and a few other chemicals to help such as toluene and methanol
Old Jan 14, 2015 | 09:23 AM
spiney's Avatar
spiney
The G2 kit comes with a can of brake cleaner.
Old Jan 14, 2015 | 09:24 AM
Tristankix's Avatar
Tristankix
Ok thanks
Old Jan 14, 2015 | 10:13 AM
ZippyNH's Avatar
ZippyNH
Try a couple cans of brake cleaner....cheaper and safer (for the caliper's rubber).....
On second thought...
Get about 50 bottles of nail polish, and paint away...then see if the nail polish catches fire, and turns brown, and flakes off...really...sounds like somebody is putting those ideas in your head...guessing it is the same person who wants you to buy "blinker fluid" or grease your brake linings to prevent wear....
On a serious note...
Painting calipers are all about preparation, and the right materials....anything else will result in an horable failure....oh yeah...I suggest you uninstall them, or unbolt them, then hang them off to the side if you don't want to bleed them, paint them in a box with thesliding areas and rubber parts masked off, etc ...
Guess you could do them in place...but lots more effort in prep and masking....
Old Jan 14, 2015 | 10:33 AM
Tristankix's Avatar
Tristankix
Ok thanks for the info! Im young and Im not going to go anything to my mini until I get some good advice from on here! Thanks.
Old Jan 14, 2015 | 08:52 PM
Fly'n Brick's Avatar
Fly'n Brick
Zip always has lots of good advice. I'd suggest searching thru ebay and amazon for the best price on blinker fluid.
I painted my calipers too only did it while replacing pads and discs. If you want a little extra 'pop' paint the disc hats as well while you're at it. it is all in the preparation or you're wasting your time and money. Also, pictures of the finished project are mandatory. Without pictures, it didn't happen.
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Oct 1, 2015 08:55 AM
