R53 Pulley Power Package - In Stock and On Sale!
Old Jan 13, 2015 | 08:47 AM
Emnotek's Avatar
Emnotek
The Complete Pulley Power Package is In Stock Ready to Ship!
Our popular Pulley Power Package is one of the best bangs for your buck. Included is the new Alta 15% or 17% Pulley, Gates Reduction Belt and NGK Cooler Spark Plugs. Click the image or links below for details.
MINI Cooper S R52/R53 Pulley Power Package
While MINI may have given the Gen1 Cooper "S" owners a literal boost over standard Coopers there is no reason to be comfortable with 163HP. One of the best ways to turn up the power is to turn up the boost with our Alta Supercharge Pulley for your Gen1 MINI Cooper S.
ALTA was the first manufacturer to design a two piece, taper fit Mini Cooper Supercharger Pulley. Today, it's the most imitated design on the market. Their latest version of the ALTA pulley has taken pulley design to the next level. Installation is easier than ever, and the results are even more fantastic.
The "cooler" plugs work great installed with a Supercharger Pulley on a Gen 1 MINI Cooper S. These "cooler" NGK plugs will get running smoother with more power through increased efficiency and heat resistance. All plugs come pre-gapped, but should be checked for .035" gap before installation. This is a great upgrade for any Gen 1 MINI Cooper!
When your Gen 1 MINI Cooper S gets into the higher miles, or you're installing a new Supercharger pulley, it's time to start thinking about replacing your belts. If you're installing a smaller supercharger pulley you will need a smaller belt to reduce the slack and allow the belt tensioner to work properly. Gates belts are used by MINI as their OEM belt supplier and trusted in racing conditions due to their high quality design.
Pulley Power Package Includes:
- Alta Supercharger Pulley
- Gates Supercharger Belt
- (4) NGK One Step Cooler Spark Plugs
Teh
Aug 22, 2022 04:37 AM
bobbiemartin
Jan 20, 2016 05:28 PM
Dec 23, 2015 10:36 AM
wkp1219
Nov 13, 2015 07:52 AM
phrza81
Oct 10, 2015 11:37 PM
