R50/53 R50 Steering wheel removal
Old Jan 7, 2015 | 09:48 AM
aslondon's Avatar
aslondon
Besides the airbag issue, is there anything I need to be aware of when removing my R50 2004 multifuntion steering wheel? Do I need a wheel puller or does the center bolt just unscrew and you lift the wheel off and unplug the little connectors.
Al
Old Jan 7, 2015 | 01:42 PM
minsanity's Avatar
minsanity
Disconnect batt, pull airbag fuse before going at it. No puller needed.
Old Jan 7, 2015 | 02:04 PM
aslondon's Avatar
aslondon
That's good news. Thanks
Al
Old Jan 7, 2015 | 02:46 PM
nkfry's Avatar
nkfry
Straight forward job, you don't have to disconnect the battery but it is good practice to do so, remove the air bag, remove the bolt, and while pulling the wheel off be careful not to pull the slip ring apart behind the wheel, then make sure to line up the missing teeth with the line (like a key way).
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 7, 2015 | 06:54 PM
aslondon's Avatar
aslondon
Thanks for the help.
Al
Dec 23, 2015 10:36 AM
skippermini
Aug 12, 2015 10:05 PM
nomar116
Aug 12, 2015 05:24 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
