:: ECS Tuning :: R90 BBS Wheels on Sale * Ziza Reverse Leds * Forge BOVs * & More
Old Dec 30, 2014 | 02:35 PM
MINI R60/R61 Forge Blow Off Adapter
Forge has created a simple, easy to install part that allows your factory boost solenoid to vent excess boost to the atmosphere, much like a blow-off valve.
The Blow Off Adapter simply bolts in between the electrical solenoid and turbocharger housing with three Allen bolts. Instead of recirculating excess charged air back into the turbo, the air is vented into the atmosphere through outlets in the adapter.
The result is that hot air is not allowed to be reused by the turbo while the critical function of a diverter valve is retained, keeping the turbo spooling and reducing lag.
Forge Ahead
Fits:
R60 MINI Countryman S/SX/JCW (2011+)
R61 MINI Paceman S/SX/JCW (2013+)
Click HERE for FORGE
R90 MINI 17" Cross Spoke Composite Anthracite Wheel Set
17x7" ET48 MINI R90 BBS Alloy Wheels
Featured on the MC40 Edition, the Genuine MINI 17-inch multi-cross anthracite spoke alloy wheels are a stunning addition to any performance-oriented MINI.
The BBS two-piece composite wheels are made in Germany and perfect for the street or the track.
*JCW 4 Piston Brake kits will need 25mm spacer for wheel fitment.
Two Piece... Too Nice...
Fits:
R50 Cooper 2002-2006
R53 Cooper S/JCW 2002-2006
R52 Cooper Convertible/S /JCW 2005-2008
R56 Cooper /S/JCW 2007+*
R55 Cooper Clubman /S/JCW 2008+*
R57 Cooper /S/JCW 2009+*
R58 Coupe' /S/JCW 2012+*
R59 Roadster /S/JCW 2012+*
*JCW 4 Piston Brakes will need 25mm spacer for wheel fitment
Click HERE for the Wheel set
MINI R52/R53 Silicone Radiator Hose Kit
Doing a cooling system refresh, or just replacing worn out and soft old hoses? Why settle for stock when you can get the added life and heat tolerance of silicone hoses? The ECS Silicone Radiator Hose Kit retains OEM fitment while resisting heat that softens the factory hoses.
All hoses come in advanced 3-ply black silicone.
Don't Get Hosed
Fits: Gen 1
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible S / JCW (2005-2008)
*Manual Transmissions Only*
Click HERE For the ECS Hose Kits
Gen2 Forge Blow Off Adapter
Forge Ahead
Fits MINI:
R56 Cooper S (2011+) / JCW (2013+)
R55 Clubman S (2011+) / JCW (2013+)
R57 Cooper Convertible S (2011+) / JCW (2013+)
R58 Coupe' S (2012+) / JCW (2013+)
R59 Roadtser S (2012+) / JCW (2013+)
Click HERE for Forge Blow Off Adapter on Sale
R50 R52 R53 Ziza LED Reverse Lights
The dim stock reverse lights might leave you guessing as to what lurks behind your car. Technology has improved, and ECS is on the forefront. Give your MINI a Ziza performance lighting makeover.
This Ziza reverse light kit has been engineered in-house specifically for your car model. We guarantee fitment and quality, with no 'bulb-out' warnings.
In addition to this kit, ECS carries a full catalog of Ziza lighting kits. Update your MINI with a complete LED line-up. More modern, more efficient, safer, better lighting. What's not to like?
Back It Up!
Fits:
R50 MINI Cooper (7/2004-2006)
R53 MINI Cooper S (7/2004-2006)
R52 MINI Cooper Convertible / S (2005-2008)
Click HERE for LEDs on Sale
R56, R57 Ziza LED Reverse Lights
Back It Up!
Fits:
R56 MINI Cooper /S/JCW (2007-8/2010)
R57 MINI Cooper Convertible /S/JCW (2009-8/2010)
Click HERE for LED reverse lights on Sale
R52 MINI Dual To Single Mass Flywheel Conversion Kit
MINI Cooper S/JCW engines deliver power in regular pulsations that are ameliorated by the mass of a flywheel. Further dampening of vibration and noise isolation is made possible by a dual-mass flywheel design, whereby two flywheels are mated together by a circumferential spring.
When positive clutch feel and shifting precision are higher priorities, minimizing any buffering between the engine crankshaft and transmission is imperative. A single flywheel design is simpler and more tactile through the clutch pedal, eliminating that vague feeling that destroys driving confidence.
Singular Perfection
Fits:
Click HERE for Valeo Kit Sale
R53 MINI Dual To Single Mass Flywheel Conversion Kit
Singular Perfection
Fits:
Click HERE for the Valeo Clutch Kits
R50 R53 MINI Helix Projector Headlights
These headlights are designed to look like the later Gen 1 MINI OEM HID Projector headlights but utilize H7 high and low beam bulbs. Feature plastic lenses with multiple choices and styles.
They are plug and play. Add some Ziza H7 bulbs for multiple output colors.
Features:
• Manual adjustable leveling
• E-code cutoffs on the projector LHD ( left hand drive )
• Multiple finishes to suit your MINI needs
• OEM design and style
*Does not contain headlight washers.
Fits:
R50 MINI Cooper (2002-2006)
Click HERE for the Helix Sale
R52 MINI Cooper Convertible Helix Projector Headlights
These headlights are designed to look like the later Gen 1 R52 MINI OEM HID Projector headlights but utilize H7 high and low beam bulbs. Feature plastic lenses with multiple choices and styles.
Features:
Project Greatness.
Fits:
R52 MINI Cooper Convertible / S / JCW (2005-2008)
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
