:: ECS Tuning :: Gen 1 Ziza Front Marker LEDs - Sale
R50 R52 R53 Ziza LED Front Markers
Small pleasures make life fun. Take your MINI; small in size, big on looks.
Why not sprinkle a little added flavor over that small pleasure with a set of bright white LEDs for your front marker lights. Just another bright idea from Ziza.
MINI Lights, Maxi Looks
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S/JCW (2002-2006)
R52 MINI Cooper Convertible (2005-2008)
Click HERE for Ziza Front Marker Kit Sale
These replace the stock front marker bulbs ( small 5watt wedge bulb ), not the amber larger bulbs that are the turn signals ( located in the same housing). See pics below.
Replace the stock clear filament wedge bulbs.
As far as color , once my Xenon lights warm up , they match very close the color, maybe a tad more blue/white.
Note * On start up with the new Ziza leds , the MINI factory LKM ( light control module) will test the circuit and cause the bulbs to flash a couple time only at first start up. Then they will stay on fine and bright.
To ensure the circuit. This happens with regular filament bulbs also you just don't see it with a filament bulb.
To ensure the circuit. This happens with regular filament bulbs also you just don't see it with a filament bulb. Thanks
THANK YOU for posting this! I thought I was losing my mind, or had installed them incorrectly. Good to know its normal. I do love the color and the brightness of them.
Thanks again!
You are welcome. Its happens mostly on the Gen 1 (above ) and Gen 2 front marker / position leds.
Total normal. Stops after about 5-6 pules. Like a cop car on start up.
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
