Oil On Top of Valve Cover
Old Dec 28, 2014 | 12:21 PM
blitzed310's Avatar
blitzed310
Detailing the R56 today I noticed more oil than I have typically seen on the top of the valve cover around the coil pack tubes. I pulled the coils out and the tubes and plugs are perfectly clean. The valve cover gasket seal itself seems pretty clean except for the location of the bolt at the top right of the head, a little gritty at that area.
Is this just the simple valve cover gasket fix or is it something else like the PCV tube not sealed properly? I have a feeling the gasket is fine since there isn't a whole lot of oil at the joint. Engine has about 48k miles
Pics for reference.
Old Dec 29, 2014 | 11:39 AM
Systemlord's Avatar
Systemlord
Has it been a while since you last detailed your engine bay? If so the PCV hoses rubber seals are worn out from all the heat. When my valve cover looked like yours I replaced it with a new one and I only see very little oil seeping out of the PCV hoses at the connector on the new valve cover. These valve covers lifespan is 50-75k miles. Also check on the back of valve cover to see if any oil is pooling right on the edge or lip of the valve cover near the intake air box.
You'll save yourself hundreds replacing the valve cover on your own rather than having to pay someone else, torque wrench needed.
Old Dec 29, 2014 | 11:45 AM
If its leakage coming from the PCV hose on the right, check that first. Or overspilled oil from an oil change. Then clean up the oil and see if it seeps again. Most of the time its leakage from a hairline crack in the valve cover or you will get a CEL for PCV leakage .
Leaking valve cover thread: N14 engine
https://www.northamericanmotoring.co...lve-cover.html
N14 engine valve cover OEM MINI part number 11127646555
http://www.ecstuning.com/Search/11127646555/ES2601877/
thanks
Old Dec 31, 2014 | 07:21 AM
nkfry's Avatar
nkfry
Sloppy oil changes are always a possibility, but I'd be willing to bet that your PCV is leaking. Unfortunately the PCV is integral to the valve cover on the gen 2 cars, and you have to replace the whole cover. As the leak progressively gets worse you will start to notice a rough idle, check engine lights, and of course more oil.
It's a quick and easy job to tackle yourself, just make sure you don't break the ground wire for the coil packs. If you do break it, make sure to put a new eyelet on and ground the strap again before starting the car, as you can/will short the ECU. We had a car come into the shop months back where this was the case.
Nick
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 31, 2014 | 07:39 AM
blitzed310's Avatar
blitzed310
It does look like the PCV, that is unfortunate I have to replace the whole cover. It's definitely not a result of sloppy oil changes, I am a ninja at that.
I was really hoping that the PCV part of the VC was able to come off so I dont have to spend the coin. I'll look into seeing if it is first able to make a better seal. The film is light and was able to wipe right off so over a period of say 6000 miles that all that came out.
I triple checked the VC seal and it is damn near spotless, and the oil cap also makes a seal and it is not coming from there....
Old Dec 31, 2014 | 11:38 AM
Systemlord's Avatar
Systemlord
Nick
What's an eyelet?
Old Dec 31, 2014 | 11:54 AM
nkfry's Avatar
nkfry
What's an eyelet?
On the center valve cover bolt at the front of the engine there is an 8mm nut on the bolt which is retaining a ground wire for the coil packs. The eyelet on the end of the wire is easily broken off, but it is also easily fixed.
On the N18 engine the ground wire is on the back of the valve cover instead of the N14 which is grounded in the front.
Phone:586-792-6464
Old Dec 31, 2014 | 11:59 AM
Systemlord's Avatar
Systemlord
Oh ok, the eyelet of a connector shape like a donut is grounding all coils. Your saying if it broke off and you installed coils without fixing the ground would toast the ECU right? If so you could have just saved members bacon!
Old Jan 7, 2015 | 03:00 PM
Down the road if the leak gets worse it might throw a CEL. The valve cover does come with the gasket and hardware. You can leave it plain or get the MINI badge and stickers.
Old Feb 19, 2026 | 09:35 AM
Clockwork's Avatar
Clockwork
Hi all, I'm reviving an older thread to ask if anyone has bought a metal valve cover?
ECS Tuning sells them (Bremmen brand) and they SEEM to have a removable top cover, where the PCV redides below it. on the OE and non-metal (Mecaplast) Valve covers, there is not an easy way to replace the PCV inside, BUT it seems with this metal Valve Cover, there IS a way to unscrew the top cover (UNLESS the screws are just for looks???) and then access the PCV to replace with a $5 valve (for the N14 engines), sold on ebay). has anyone successfully opend the top of the metal valve cover to dot his?
I am also hearing that the metal valve covers warp just like the Mecaplast (plastic looking) covers, so then is the ONLY reason to get a metal, strictly for looks?
I need to buy something from ECS Tuning within a few days, as I'm travelling to USA for a bit and the free shipping to hotels is a nice savings as opposed to sending it across the border and paying a rapage (duties and handling) fee to tthe shipping company.
09R56
Nov 16, 2022 10:49 AM
bobbiemartin
Jan 20, 2016 05:28 PM
PaulWalliDumali
Aug 21, 2015 04:46 PM
Lex2008
Aug 16, 2015 08:33 PM
eliseo1981
Aug 6, 2015 05:00 AM
