:: ECS Tuning :: MORE Ziza Plate LEDs on Sale * Pipercross JCW Filter * ECS Spacers *
MINI R58 Coupé | R59 Roadster P3Cars VIDI
Before your next stop light liftoff, add a space age digital system monitor to your cockpit. P3Cars Vent Integrated Digital Interface is a plug-and-play data display that "fits like factory," in easy view of the pilot seat.
Pop it on and plug it into your car's onboard diagnostic connector. Then scroll through critical vehicle parameters and monitor manifold pressure, system temperatures, and other vital stats.
No programming, coding, cutting, or splicing.
Reads MINI Check engine codes and clears them with a touch of the button.
Just tons of fun.
Engage
Fits:
R58 MINI Coupe /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for P3 Cars Kit
MINI R60/R61 Ziza LED License Plate Kit
You won't believe the difference an LED lighting package makes on your car until you see it with your own eyes. LED illumination is a far brighter and friendlier light, crisp and clean, especially when compared to the dingy yellow glow from conventional filament style bulbs.
Ziza lighting is proud to introduce LED license plate bulbs for your MINI that will not cause a "bulb out" warning. These are direct replacement bulbs that install in minutes, there is no need to wire up fancy resistors or rework your factory wiring to get them functioning properly.
Brighter Is Better
Fits MINI:
R60 Countrayman / S / SX All4 / JCW (2011+)
R61 Paceman / S / SX All4 / JCW (2013+)
Click HERE for the Ziza kit
R50/R53 MINI LED Interior Lighting Kits - Holiday Sale
Some products need to be experienced to be appreciated.
We can talk about our LED interior lighting kits, but words will fail. We can describe the light as bright and white, crisp and clean. We can even tell you that our complete interior LED kit will banish ugly yellow illumination and showcase the rich features of your dash and interior trim like never before, but it won't do them justice.
Oh well. Guess you'll just have to take advantage of our free shipping on full kits, and see for yourself what a dramatic change LEDs can make to your car, both inside and out.
Ziza; Light Years Ahead
Fits:
R50 MINI Cooper (7/2004-2006)
R53 MINI Cooper S / JCW (7/2004-2006)
Click HERE For the Ziza interior Kits
R55 Clubman Ziza LED License Plate Kit
Brighter Is Better
Fits:
R55 MINI Clubman "Base" (2008+)
R55 MINI Clubman S (2008+)
R55 MINI Clubman JCW (2009+)
Click HERE for Ziza Clubman kit on Sale
R58 R59 FK Checkered Car Cover
Keep dust, dirt and other elements off your car during indoor storage with this new single layer nylon universal car cover from FK.
Blue sides and black and white checkered center gives your car great looks, even when you can't see it.
This particular cover is intended for indoor use, and uses high-quality materials for exceptional protection of your MINI.
Got You Covered
Fits MINI:
R58 Coupe' /S/JCW (2012+)
R59 Roadster /S/JCW (2012+)
Click HERE for Car cover on Sale
R52 Convertible S Pipercross Air Filter
Designed as an original equipment replacement, a Pipercross filter replaces the factory air filter within the airbox. Installation is as simple as opening the airbox, discarding the old filter and replacing it with a free-flowing Pipercross air filter.
Why foam? Because it is better!
Airborne dirt particles quickly clog conventional paper or cotton-gauze style filters, resulting in a pressure drop that robs the engine of airflow and power.
perFOAMance
Fits MINI:
R52 Cooper Convertible S (2005-2008)
*non JCW Kit or Airbox*
Click HERE for Pipercross Performance Air Filter on Sale
R50 R52 R53 Ziza LED Front Markers
Small pleasures make life fun. Take your MINI; small in size, big on looks.
Why not sprinkle a little added flavor over that small pleasure with a set of bright white LEDs for your front marker lights. Just another bright idea from Ziza.
MINI Lights, Maxi Looks
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S/JCW (2002-2006)
R52 MINI Cooper Convertible (2005-2008)
Click HERE for Ziza Front Marker Kit Sale
Gen1 '02-'7/06 ECS 25+30mm Wheel Spacer Kits
Don't let conventional spacer options leave you feeling down and out. ECS bolt-on wheel spacers are the right way to push your wheels out to the fenders.
These precision machined, 6061-T6 anodized black aluminum spacers have 4140 integral steel threads. Forget the perils of extra-long wheel bolts; these come complete with all the low profile bolts needed to properly torque the spacers to the hub in factory looking black and your wheels to the spacers.
ECS bolt-on spacers will have your car sitting just wide.
Space Out
Fits:
R50 MINI Cooper (2002-7/2006)
R52 MINI Cooper Convertible / S / JCW(2005-7/2006)
R53 MINI Cooper S / JCW (2002-7/2006)
Click HERE for the ECS wheel spacer Kits
R56, R55, R57 Cooper S & JCW Pipercross Air Filter
perFOAMance
Fits:
R56 MINI Cooper S (2007-8/2010)* & JCW (2009-2012)*
R55 MINI Clubman S (2008-8/2010)* & JCW (2009-2012)*
R57 MINI Cooper Convertible S (2009-8/2010)* & JCW (2009-2012)*
*JCW Tuning Kit Airbox
Click HERE for the Pipercross JCW Sale
Gen1 7/06+ ECS 25+30mm Wheel Spacer Kits
Space Out
Fits:
R50 MINI Cooper (7/2006+)
R52 MINI Cooper Convertible / S / JCW(7/2006 - 2008 )
R53 MINI Cooper S / JCW (7/2006+)
Click HERE for the ECS Wheel Spacers
Jan 4, 2019 12:51 PM
Accessory Products
Aug 11, 2015 12:37 PM
Aug 11, 2015 11:58 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
