15" winter rims
Old Dec 7, 2014 | 06:46 AM
Avro's Avatar
Avro
15" winter rims
I'm looking for a used set of rims to mount winter tires to, but all I can find on Kijiji in my area are 15". My 2011 Clubman currently has 16" tires on. Can I use 15" for my winter set? Will it affect my speedometer readings and handling much?
Avro
Old Dec 7, 2014 | 07:29 AM
TrailGuide2004's Avatar
TrailGuide2004
Wheel size will not affect your speedo it is the outside diameter of the tire that will do that but with a smaller wheel you will need more sidewall on your tire yo get the same diameter you have now which will have more flex in turns.
Old Dec 7, 2014 | 08:42 AM
ashchuckton's Avatar
ashchuckton
If your clubman is an S model 15" rims will not clear the front brakes & you will need a 16" rim. If it is a non-S those 15" rims will work & are preferred by me for winter use.
Old Dec 7, 2014 | 03:50 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Try going to terrace.com and plug in your MINI in upgrade garage then select winter wheels and tires to see your options.
As mentioned the Cooper S has large front brake calipers vs the base Cooper so 16" winter wheels would be the smallest. Tire sizes in either 15" or 16" are OK for the MINI, just match tire diameter of about 24.3" and use a narrow width tire. Speedometer and odometer should be OK.
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
luisfv56
Nov 16, 2015 01:55 PM
malibujoey
Nov 9, 2015 08:22 PM
Winston46
Nov 9, 2015 06:18 AM
