Coolant coming from reservoir
Old Nov 25, 2014 | 12:54 PM
zman112233's Avatar
zman112233
Hi all!
New the forum, thanks for having me.
Here is what I've got going on:
About a year ago I had all the cooling hoses, water pump and thermostat replaced on my 03 Mini Cooper S because it was leaking coolant from the water pump. Everything has been fine until I was sitting in the driveway listening to the radio with the engine running for about 5 mins before I went into the house. I got out and the fan kept running for a solid minute. I looked underneath and there was a small puddle of coolant. It was obviously coming from the reservoir itself (couldn't tell if it was boiling over or leaking from the seams of the tank) It was a fairly cool day and the temp gauge never moved past normal. I've been checking the coolant daily since then and it seems to be dropping a little bit every day but the temp gauge never goes above half way. I've also checked the oil and it's nice and clean at a normal level.
Any suggestions on what it could be?
Old Nov 25, 2014 | 01:06 PM
JAB 67's Avatar
JAB 67
why are you certain that it is coolant and not condensate from the a/c system?
Old Nov 25, 2014 | 01:12 PM
zman112233's Avatar
zman112233
It's definitely not A/C condensation. I soaked it up with a towel and verified it's coolant.
Old Nov 25, 2014 | 02:44 PM
minsanity's Avatar
minsanity
Cap? split seams? Permanent Fix: Canton or RMW coolant tank w/ real caps.
So worth the money.
Kimolaoha
Jul 5, 2023 01:04 PM
blackie
Jan 18, 2017 09:56 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
David.R53
Sep 1, 2015 06:49 PM
kwijmbo
Aug 5, 2015 09:00 PM
