Window Gap and resetting it
Old Nov 21, 2014 | 06:16 AM
Challo's Avatar
Challo
Hi All,
My passenger side window has a small gap about 3mm at the top of the glass when its fully closed. The window is able to open/close as normal, and when I open the door it drops down as normal, and goes up when the door is closed. It must of happened when I disconnected the battery.
Issue is it doesn't fit snug into the rubber as the other window does, leaves a few mm gap at the top, causing wind noise at speeds and letting damp cold air into the car so is causes condensation.
I have looked online and found a few ways to reset the window, but nothing seems to work. Anything else i can try? Or does it look like a trip to the dealer for a software upgrade?
Old Nov 21, 2014 | 08:21 AM
Ridick_Bowen's Avatar
Ridick_Bowen
There are a few threads on here about how to adjust the window up a few mm. Something pertaining to removing the door panel and using a special clamp tool to adjust it up or down.
USNAE2
16
Jun 17, 2022 07:17 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
semibreve42
Oct 2, 2015 09:06 AM
rt808
Sep 25, 2015 01:59 PM
