R53 Ticking Noise w/video Help!Please!
Old Nov 20, 2014 | 11:11 AM
pkx's Avatar
pkx
Hello everyone,
I am new to Mini, got my 06 MCS JCW two month ago and I really enjoyed it. However, as temperature dropped these days I found a ticking noise somewhere near the supercharger on the passenger side. Anyone know what might caused it?
Here is the video I recorded
Mini Cooper S JCW(R53) ticking noise - YouTube
"> Mini Cooper S JCW(R53) ticking noise - YouTube
" type="application/x-shockwave-flash" width="425" height="350">
Any inputs would be appreciated, thank you!
Old Nov 20, 2014 | 07:32 PM
rudomundo's Avatar
rudomundo
Welcome to NAM. Have a friend depress the clutch pedal all the way while you listen. If the ticking goes away, it is "clutch chatter," nothing to worry about. Motor on.
Old Nov 20, 2014 | 11:34 PM
AudioNToxication's Avatar
AudioNToxication
Just for kicks, with the motor off pull the hose off the valve cover, plug it real good with your thumb and have someone start the car. If the noise goes away, get a new pcv valve.
Old Nov 23, 2014 | 07:06 PM
pkx's Avatar
pkx
tried it but the click is still there, thanks though.
Old Nov 23, 2014 | 11:49 PM
yukinoinu's Avatar
yukinoinu
erm my ford did this (2012) but it was slower, it was the cams.
Old Nov 24, 2014 | 05:01 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Sounds like the hydraulic belt tensioner #1 below.
Is the ticking rotational varying with RPM's ?
There is a metal strap built thru the middle of the spring. If the belt is stretched/worn it will chatter and if the hydraulic belt tensioner is shot it will make that noise too. There are a series of holes in the strap and when viewed down in from the front with a flashlight, you should see at least one complete hole showing at the top of the assembly when belt is in good shape.
Old Dec 7, 2014 | 06:35 PM
gbx's Avatar
gbx
its your Timing tensioner about 70.00
Finhead
105
Aug 14, 2023 07:51 AM
rikaro
Aug 7, 2021 02:33 PM
Melvinyip
Apr 17, 2020 09:28 AM
Spank
11
Apr 9, 2020 02:23 PM
bansasn
15
Sep 4, 2015 01:24 PM
