:ECS Tuning: Ziza Reverse LEDs }{ ECS Silicone Hose Kit } MINI OEM Steelies : Winter
MINI R56/R57 LED Reverse Light Kit
Tired of that sickly flicker from your reverse lights? Want some real light back there? Useful light? Light that lets people know you are backing? Light that better illuminates behind you for added safety?
If so, what you need is a set of Ziza LED reverse lights. Brighter than stock, these direct fit LEDs cast a bright white light, far more useful than the puny yellow glow from stock bulbs.
The bulbs have a standard bayonet base that fits stock sockets perfectly; with metal heat sinks to keep them cool. Twist out the old bulbs; twist in the new.
See the difference.
Fits:
R56 MINI Cooper /S/JCW (2007-8/2010)
R57 MINI Cooper Convertible /S/JCW (2009-8/2010)
Click HERE for Ziza
R52 Mini Cooper S/JCW ECS Silicone Hose Kit
Doing a cooling system refresh, or just replacing worn out and soft old hoses? Why settle for stock when you can get the added life and heat tolerance of silicone hoses? The ECS Silicone Radiator Hose Kit retains OEM fitment while resisting heat that softens the factory hoses.
All hoses come in advanced 3-ply black silicone.
Don't Get Hosed
Fits:
R52 MINI Cooper Convertible S / JCW (2005-2008)*
*Manual Transmissions Only
Click HERE for the ECS Rad Hose kit
MINI R58/R59 Oil Service Kits
The best oil for your MINI? Clean oil. Regular oil changes with a quality filter cartridge are cheap insurance against costly breakdowns, and the best way to keep your MINI healthy.
Now you can perform this essential service yourself and save big with MINI oil change kits that contain an OEM filter cartridge with drain plug & crush washer, plus your choice of name brand engine oils that meet BMW LL-98 and BMW LL-01 standards.
Spend a little up front and head off major repairs, down the road.
Drain Your Oil, Not Your Wallet
Fits:
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+
Click HERE For the oil service kits
MINI R60 R61 H&R Sport Springs
The most popular spring in H&R's line-up, Sport Springs will lower your Countryman average 1.4" front and 1.4" rear, Paceman average 1.3" front and 1.25" rear for a lower center of gravity, improved handling, and a more aggressive appearance.
Sport springs are an excellent choice for street and occasional track use, featuring a spring rate that is firmer than the OE Sport spring but still comfortable enough for daily use.
A Tasteful Upgrade
Fits:
R60 Countryman (2011+)
R60 Countryman S (2011+)
R61 Paceman (2013+)
R61 Paceman S (2013+)
R61 Paceman SX (ALL4) (2013+)
Click [COLOR=Red]HERE[/COLOR H&R sport springs.
MINI R55-R59 Base Steelies ( Justa Cooper )
Genuine MINI steel wheels are arguably the best solution for the enthusiast looking for a practical, affordable winter wheel setup.
The strong metal construction and 5.5” width make for a rugged, highly serviceable arrangement capable of withstanding the rigors of winter weather.
Genuine MINI Wheel Hub Caps are also available, completing the look and further protecting your wheels.
MINI silver inner center caps with MINI logo are yet another option, giving your steelies a slick OEM appearance.
Real Steel.
Fits: ( NON S or NON JCW models )
R56 Cooper (07+)*
R55 Clubman (08+)*
R57 Convertible (09+)*
R58 Coupe (12+)*
R59 Roadster (12+)*
*Not for models with JCW brakes or JCW Brake kit.
Click HERE for steelies set
MINI R55-R59 (S) Steelies Cooper S Models
MINI silver inner center caps with MINI logo are yet another option, giving your steelies a slick OEM appearance. The caps attach behind the lug bolts securely; one cap required per wheel.
Fits:
R56 Cooper S (07+)*
R55 Clubman S (08+)*
R57 Convertible S (09+)*
R58 Coupe S (12+)*
R59 Roadster S (12+)*
MINI R50-R53 Base & S Steelies
Real Steel.
Fits:
R50 MINI Cooper (2002-2006)*
R52 MINI Cooper Convertible / S (2005-2008)*
R53 MINI Cooper / S (2002-2006 )*
Click HERE for Steelies Options and center caps
MINI R60/R61 Countryman/Paceman Steelies
The strong metal construction and 6.5” width make for a rugged, highly serviceable arrangement capable of withstanding the rigors of winter weather.
Real Steel.
Fits:
R60 MINI Countryman /S/SX/JCW (2011+)
R61 MINI Paceman /S/SX/JCW (2013+)
Click HERE for the Steel wheel sets
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
Jan 30, 2021 01:35 AM
