R50/53 2006 Cooper Dashboard Lights Burned Out?
Old Nov 16, 2014 | 03:08 AM
rphox2003's Avatar
rphox2003
I just noticed that the climate control panel (the one above the windows/doors switches and below the CD player) in my center console has no backlighting when I turn on my lights.
The panel with the windows/doors switches has backlighting and I have an after-market CD player, so they are OK. I can't remember if the climate control panel ever did have the backlighting.
My question:
If it is supposed to have backlighting, can I fix it myself (fuse or bulb replacement)?
Thanks.
Old Nov 17, 2014 | 05:08 AM
jamez's Avatar
jamez
Subscribed.
The climate controls have at least 2 lights behind. My left one (temperature and half of the next) is loose and flickers/fails regularly.
I want to hear what others recommend for repair, but as far as I know, its a replacement of the climate control section as they're likely surface mounted soldiered LED's like in the tach and spedo (unless you have the skills/people that can handle that).
Old Nov 17, 2014 | 05:18 AM
rphox2003's Avatar
rphox2003
A search I did yesterday came up with a fairly detailed procedure for removing the unit and replacing the bulbs - something that looked beyond my ability and patience.
As my backlights seem to have both gone out at once, I was just wondering if it could be a fuse, which would be a whole lot easier to fix.
I looked at the diagram on the inside of the interior fuse box cover, but didn't see anything that was definitely pointing at the climate control unit. Any help is appreciated.
bigramdizzle
Aug 6, 2019 09:19 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
