Good tools to have?
Old Nov 11, 2014 | 01:50 AM
yukinoinu's Avatar
yukinoinu
Good tools to have?
So Christmas is around the corner, I am going to be doing all the work on my car myself. What are some good tools to have for a Cooper S? I have gloves and 2 more jack stands on for sure. What should I get also? I plan to buy a low profile jack soon just don't know when.
Old Nov 11, 2014 | 04:05 AM
Capt_bj's Avatar
Capt_bj
GOOD sockets - MINI is metric but save $ and just go ahead and get a set that includes both
GOOD box wrenches for when a socket just won't do
TORX drivers and or sockets (MINI uses a lot of TORX fasteners, all the way up to T-50)
Screwdriver set
Pliers
{can be accomplished by buying a good quality mechanics set from Lowes or Sears/Craftsman for around $100}
special socket for oil filter (big)
Torque wrench for wheels
air compressor for tires (don't think about air tools tho until you are ready for a big compressor)
Old Nov 11, 2014 | 06:19 AM
buzzsaw's Avatar
buzzsaw
floor jack/jack stands
shop light
Old Nov 11, 2014 | 07:27 AM
JAB 67's Avatar
JAB 67
Brake caliper tool (retracts and rotates rear caliper pistons)
Tensioner tool (so you can replace your s/c belt)
Old Nov 11, 2014 | 08:19 AM
v10climber's Avatar
v10climber
It depends on what kind of jobs you're planning on tackling. Basic jobs will really just require a basic metric socket set and wrenches, pliers, screwdrivers and torx bits. Plus various size torque wrenches and probably a breaker bar.
Old Nov 11, 2014 | 11:19 AM
Slave to Felines's Avatar
Slave to Felines
I would recommend getting jack stands that are locked with a pin, not the ratchet kind. I have a friend who bumped the handle of a ratchet jack stand, and had a car fall on him while he was working on it. He wound up getting his face reconstructed by a surgeon.
Pin-type jack stands are OSHA approved; ratchet-type jack stands are not. There is a reason for that...
Old Nov 11, 2014 | 01:25 PM
Capt_bj's Avatar
Capt_bj
MOST IMPORTANT if you don't have one
a garage big enuf to work in! Ideally with electricity and a small refrigerator . . .
Old Nov 12, 2014 | 12:58 PM
yukinoinu's Avatar
yukinoinu
Capt bj- I have a small garage.... use to a 3 stall now have a 2 stall which can only fit my mom's mini...
I pretty much have most of those listed, some new ones. I do need TORX for sure, and I have a ratchet gun, and I am getting some new sizes and a converter so I can use a ratchet gun basically on my whole car
I need driving gloves.... as non manly as that sounds I was touching my steering wheel and shifter as little as possible... it was 30 when I was driving...
Old Nov 12, 2014 | 02:38 PM
Capt_bj's Avatar
Capt_bj
um
so rather than starting from zero, you have a decent set of tools (including a compressor and basic air tools) and are only wondering about MINI specific stuff?
'needing driving gloves' is not what your original tag line asked for . .
checking out of this thread . . .
Old Dec 24, 2014 | 12:39 PM
garthg's Avatar
garthg
Mini also used e-torx (internal torx). You can buy the few that you need as you go. (i.e. right side motor mount E-12).
Old Dec 24, 2014 | 01:22 PM
DneprDave's Avatar
DneprDave
You will also need a long, narrow, 14 mm 12 point spark plug wrench to change the spark plugs.
http://www.waymotorworks.com/long-sp...-r61-mini.html
Dave
Old Dec 24, 2014 | 03:48 PM
Eric_Rowland's Avatar
Eric_Rowland
Dave
Only if you have a Gen 2. Gen 1's use conventional plug socket.
Old Dec 24, 2014 | 11:01 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Tire pressure gauge
LED work light
Old Dec 25, 2014 | 07:12 AM
ZippyNH's Avatar
ZippyNH
Originally Posted by Capt_bj
um
Hmm.
Driving gloves? Tools?! I'm confused!!
And airtools can make a mess if you don't have the basic skills with ratchets, etc...
Have some anti-seize...get the BIG jar...dielectric greese, some penetrating lube, a prybar,...and a bit of common sense...
Old Dec 26, 2014 | 06:31 AM
gregsmini's Avatar
gregsmini
Originally Posted by ZippyNH
Hmm.
mmm...I've been looking everywhere for a jar of the "bit of common sense"...Amazon, ebay, Wal-Mart....seems to be out of stock...don't know when it will be available....
Old Dec 26, 2014 | 08:00 AM
Capt_bj's Avatar
Capt_bj
right next to the replacement LUCAS wiring loom smoke
Old Dec 26, 2014 | 05:10 PM
Drivehard's Avatar
Drivehard
That bottle can be put right next to this one
Sent from my iPad using NAMotoring
Kimolaoha
Dec 5, 2020 09:32 PM
Aug 21, 2015 11:25 AM
FLYM1N1
Aug 17, 2015 07:15 AM
minipopkart
Aug 13, 2015 05:22 AM
pyrrhusmj
Aug 6, 2015 07:42 AM
