Low Speed Fan Relay bad?
Old Nov 7, 2014 | 06:42 AM
shub's Avatar
shub
Hello, I am having the ubiquitous low speed fan issue. At the connector in the engine bay, I put a jumper between the two positive wires. My hope was that when the low speed relay called for the fan, it would jump over to the high side stage, until I can get the fan or resistor replaced.
But with this arrangement the high speed still only comes on when the car gets REALLY hot. Does this mean the low speed relay is not sending a signal? Is there a way to test that?
Old Nov 7, 2014 | 06:58 AM
ovix's Avatar
ovix
Yes.
All the relays are identical, so you can switch them and see what happens.
However, my opinion is that the relays are fine, but you made some error when jumping low speed.
Old Nov 7, 2014 | 07:16 AM
shub's Avatar
shub
Okay, Basically all i did was separate the connector harness and wrapped a 20 ga solid wire around the two pins figure 8 style and crimped with needle nose before reassembling. I'll put a continuity tester between the pins, maybe my connection sucks. Then I'll test the relays, thank you
Old Nov 8, 2014 | 03:49 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes the low speed on the fan is pretty common failure.
We sell the low speed resistor as an individual part since it fails so often.
http://www.waymotorworks.com/radiato...0-r52-r53.html
Old Nov 10, 2014 | 06:44 AM
shub's Avatar
shub
Turns out the 30A fuse for the low speed was blown. I didn't realize at first that it had its own fuse. Replacing it got the relay to work again, but the resistor is still open circuit, but at least so was able to jump the high speed until I get around to doing a more thorough repair.
Old Nov 10, 2014 | 07:41 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by WayMotorWorks
...We sell the low speed resistor as an individual part since it fails so often.
Why sell this one rather than he Dorman one which looks much beefier? What is your experience with the Dorman one?
Thanks in advance.
///Rich
Old Nov 11, 2014 | 07:13 AM
shub's Avatar
shub
I'm leaning towards this: http://www.amazon.com/gp/aw/d/B008MLKUCC/ref=mp_s_a_1_1?qid=1415717009&sr=8-1&pi=SY200_QL40
silence2-38554
Nov 12, 2015 09:39 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
David.R53
Sep 1, 2015 06:51 PM
David.R53
Sep 1, 2015 06:49 PM
