:ECS Tuning: FORGE Intake Hoses N14/ BOV kits |*Vaico Parking Brake Kit | "BlackLINE"
Old Nov 5, 2014 | 12:27 PM
R56/R55/R57 MINI Cooper S/JCW Silicone Intake Hose Kits
The R55/R56/R57 N14 engine intake was designed with practicality in mind, presenting an obstruction and misdirection of airflow creating turbulence that effectively minimizes intake plenum volume.
Forge Silicone Intake Hose Kits exhibit a less severe intake angle and direct air across a perfectly smooth surface.
The thick silicone rubber inlet hose is reinforced with nylon cording to provide stability and durability, while an attractive gloss finish imprinted with the Forge brand name oozes performance.
New hose clamps are included to complete installation.
Forge Ahead
Fits:
R56 MINI Cooper S (2007-2010) / JCW (2009-2012)
R55 MINI Clubman S (2008-2010) / JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) / JCW (2019-2012)
Click HERE for Forge Intake hose
R58/R59 MINI JCW Forge Silicone Intake Hose Kits
The R58 MINI Coupe JCW/R59 MINI Roadster JCW N14 engine intake was designed with practicality in mind, presenting an obstruction and misdirection of airflow creating turbulence that minimizes intake manifold volume.
Forge Silicone Intake Hose Kits exhibit a less severe intake angle & direct air across a perfectly smooth surface.
The thick silicone rubber inlet hose is reinforced with nylon cording to provide stability & durability, while an attractive gloss finish imprinted with the Forge brand name oozes performance.
New hose clamps are included to complete the installation.
Forge Ahead!
Fits:
R58 MINI Coupe' JCW (2012)
R59 MINI Roadster JCW (2012)
Click HERE for the FORGE intake hoses
MINI Gen 1 Vaico Parking Cable Refresh Kit
Having proper use of your emergency brake in your MINI is a must.
Over time, brake cables can develop rust inside the plastic boot rubber, making the cable susceptible to corrosion and eventually seizure.
If your emergency brake seems to stick and lock your rear brake, or if the parking brake has failed completely, Vaico replacements for both sides are now available from ECS tuning.
Park It
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible S / JCW (2005-2008)
Click HERE For the Vaico Parking brake kit.
MINI Gen2 S/JCW N18 Forge Blowoff Valve Kits
Ready to blow off a little steam? Get Forge under your hood.
Stock diverter valves just can't handle performance upgrades. Add a little boost and they get all weak in the knees and go to pieces.
Forge knows this. That's why they've engineered boost-hardy blow off and diverter valves tough enough to take the pressure without blowing their lids.
Aluminum housing. Faster Response. Works and plays well with engine management systems.
Forge Forward
Fits MINI:
R56 Cooper S (2011+) / JCW (2013+)
R55 Clubman S (2011+) / JCW (2013+)
R57 Cooper Convertible S (2011+) / JCW (2013+)
Click HERE for Forge Blow off valve kits .
R60 MINI Black Line Headlight And Tail Light Trim
Genuine MINI 'Black Line' Headlight and Tail Light Trims bring a subdued black look to your factory headlight chrome or black housings and tail light red housings.
The kits include both the left and right side tail light or headlight trims, allowing you to refresh look of your MINI R60 MINI Countryman/S/SX/JCW in a single kit.
And because the parts are genuine MINI, fitment and quality are guaranteed.
Authentic Black Line
Fits:
R60 MINI Countryman Base / S / SX / JCW (2011+)
Click HERE for blackline kits
MINI R113 JCW Wheel & Tire Sets *SALE*
ECS now offers a superbly matched wheel and tire set from legendary MINI tuner JCW. The 18-inch JCW LM Rad Cross Wheels are finished in Gloss Turned Black or Gloss Black and are wrapped with Pirelli P Zero or Bridgestone Potenza RF asymmetrical Run Flat High performance tires.
The combination not only perfectly complements any MINI's styling, but offers fitment, quality, and performance only possible through JCW. The balanced wheels with MINI JCW center caps and TPMS sensor arrive ready to mount - just top off with air and drive.
Fits MINI:
R50/R52/R53 Cooper/S/JCW (02-08)
R56 Cooper /S/JCW (07+)*
R55 Clubman /S/JCW (08+)*
R57 Convertible /S/JCW (09+)*
R58 Coupe /S/JCW (12+)*
R59 Roadster /S/JCW (12+)*
Fits up to 9/09 with TPMS sensor included:
9/09+ will need to swap sensor out to ES2763259
Click HERE for the wheel kits
MINI Countryman / Paceman N18 Forge Blowoff Valve Kits
Forge Forward
Fits MINI:
R60 Countryman S / SX / JCW (2011+)
R61 Paceman S / SX / JCW (2013+)
Click HERE for Forge N18 CM / PM BOV
MINI R52|R53 Cooper S / JCW Forge Silicone Intake Hose
The MINI R52/R53 Cooper S / JCW engine intake was designed with practicality in mind, presenting an obstruction and misdirection of airflow creating turbulence that minimizes intake manifold volume.
Forge Ahead
Fits:
R52 MINI Cooper Convertible S / JCW (2005-2008)*
R53 MINI Cooper S / JCW (2002-2006)*
*For vehicles with manual transmissions
Click HERE for the Forge silicone kits
Toolman
Jan 20, 2016 06:50 AM
wkp1219
Nov 13, 2015 07:52 AM
tr3y003
Oct 22, 2015 10:48 AM
elightbo
Aug 17, 2015 01:50 PM
