R50/53 Leak can't figure it out!
Old Oct 28, 2014 | 07:32 AM
Big John O's Avatar
Big John O
Got up this morning noticed a leak under my 2006 mini. after checking leaking seems to be coming from two bolts sticking down under the car. Leak is clear oily substance, checked brake fluid full, motor oil down 1/2 quart which always seemed normal to me, fluid is oily but clear and no smell. Manual trany, clutch seems to work ok. HELP
Old Oct 28, 2014 | 07:43 AM
quikmni's Avatar
quikmni
Could use a little more information to help.
Is your 2006 Mini an S or standard Mini?
What are the bolts connected to?
Where are the bolts?
Is it just fluid dripping from above onto these bolts?
How about a picture.
Old Oct 28, 2014 | 01:40 PM
nkfry's Avatar
nkfry
Without more information I would say it's powersteering fluid, which is a very common leak on these cars unless you replace the crimp clamps the factory uses with worm style clamps.
More information would be required to diagnose what exactly your leak is, but clear and oily leads me to believe it's powersteering fluid.
Nick
Detroit Tuned
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Oct 31, 2014 | 08:48 PM
David.R53's Avatar
David.R53
Noticed the OP hasn't responded to questions, so will add without expecting much - The supercharger oil is clear as well, assuming you have a supercharger. Not much to leak out - and pricey to replace - its in the front of the engine of course.
The power steering reservoir is close to the firewall. The power steering fluid is slightly amber, but a thin layer probably looks clear.
If you haven't seen this trick before, leaving a clean sheet of cardboard under the car overnight helps pinpoint drips.
Filmy
15
Jun 6, 2023 06:27 AM
hockeydad51
Oct 9, 2015 01:51 PM
marc0011
Sep 10, 2015 10:04 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Sep 2, 2015 09:05 AM
