R58 N18 Spark Plugs
Old Oct 23, 2014 | 05:09 AM
VX crazy's Avatar
VX crazy
N18 Spark Plugs
Has anyone changed plugs, which did you use? I cant find a lot of options, looking at the Way Motor Works NGK R plug which is a cooler plug. I am not HIGHLY modified, just have intercooler, exhaust and JB tune as far as engine goes, and wonder if this plug would be better than stock? IF I stay with stock plug that would be the Behr plug correct? I have about 30k and checked a plug and they need to be replaced, I am thinking due to the JB tune the car runs richer. Any advice would be great!
Old Oct 23, 2014 | 06:01 AM
cerenkov's Avatar
cerenkov
The stock should be fine for you (the colder ones won't hurt). The plugs are Beru. Just make sure that you buy the 14mm special socket (EDIT, obviously you have one that works since you pulled one out already).
Old Oct 23, 2014 | 12:14 PM
Stock plugs will be fine, which are Beru. +1 on the 14mm 12 point socket with an extension.
http://www.ecstuning.com/Search/SiteSearch/ES2561145/
http://www.ecstuning.com/Mini-2012-Cooper_Coupe-R58-Cooper_S-Coupe-N18B16A/Engine/Electrical/2
eliseo1981
May 10, 2016 05:19 AM
JMF1975
Sep 11, 2015 03:29 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 4, 2015 03:56 PM
Sep 2, 2015 09:05 AM
