R50/53 05MCS cranks but no start need tech manual
06 MCS was hard starting for a week or two and fine there after now cranks and wants to start but won't. Confirmed spark at wires, need to pull plugs and check
Fuel pump seems to prime when key turned on, fuel pump fuse looks good
I need to test relay. If these all pan out I suppose a fuel pressure check is in order?
Check engine light is currently out but was throwing cylinder 3 misfire weeks ago when hard starting.
I am hoping someone has an iPad compatible shop tech manual they wouldn't mind sharing - and of course any advice would be truly appreciated
Thank you
Thank you
2005mcs
No recent mods. Long story. Car sat a long time took on water (plugged sunroof drain) needed a wiring harness, once running again it had the over heating issue. We changed a thermostat and housing and still overheated under heavy load until I figured out the bleeding procedure. Than all was well till this issue.
Will check plugs next day or two and see if fuel is delivered when cranking
09R56
Nov 16, 2022 10:49 AM
gmonde
Sep 8, 2015 06:37 AM
tacticalbacon02
Aug 22, 2015 06:05 PM
