DSC/ABS Codes - 5E19, 5E5C, 5E14
Old Oct 17, 2014 | 08:17 AM
jamfred774's Avatar
jamfred774
I am getting the following codes from my DSC system per the BMW C110:
5E19 CAN data fault from DME/DDE (DSC Lamp on as long as error is present)
5E5C Initialize Run Flat Indicator, See owners handbook
5E14 CAN connection to DME/DDE (DSC lamp on until ignition reset)
When testing the DSC here is what it pulls up:
10, 41, 00, 09 No Found
I am having trouble finding anything on the second part (10, 41, 00, 09 No Found). Does anyone know what those mean? It seams the connection on the module might be corroded for the first 3 codes from what I am reading.
Old Oct 17, 2014 | 08:53 AM
jamfred774's Avatar
jamfred774
Also when searching for DTC errors I am getting:
0A, 49, 00, 00 No Found!
Old Oct 17, 2014 | 08:57 AM
jamfred774's Avatar
jamfred774
2003 Fault Code List
I found this on another site but didnt know if it was right or not.
0 Not identified error
1 ABS-Hydro aggregate
2 Throttle valve Signal
3 Ignition time error
4 Rear left speed sensor faulty OR ABS-inlet valve
5 Rear right speed sensor faulty OR ABS-inlet valve
6 Front right speed sensor faulty OR ABS-inlet valve
7 Front left speed sensor faulty OR ABS-inlet valve
8 Rear left ABS-valve faulty
9 Rear right ABS-valve faulty
10 Front right ABS-valve faulty
11 Front left ABS-valve faulty
12 Gear box intervention
13 Idle speed RPM increasing
14 Valve relay fault
15 ABS Back-delivery pump fault
16 Throttle valve reduction
17 Front left wheel sensor
18 Front left Wheel sensor
19 Accumulator-Pressure limit
20 Front left Wheel sensor OR EGS-Intervention error
21 Front left Wheel sensor OR ABS/ASC-control-unit defect
22 Speed sensor signal : faulty
23 Equipment ERROR (Automatic/Manual)
24 Incorrect gear wheel on one of the four wheels
25 Line interruption-brake light switch
27 Idle speed Feed back Signal
30 Left rear wheel speed sensor cable
31 Right rear wheel speed sensor cable
32 Right front wheel speed sensor cable
33 Left front (E38/E39) or Right (E46) wheel speed sensor cable
34 Wheel sensor : front right or ASC switch over valve
35 Break Liquid Level Signal Error
36 Front right Wheel sensor OR Ignition signal Error
37 Front right Wheel sensor OR ABS/ASC Control Unit :Internal Error
38 Gas-Valve-Adjustment Error
39 Servo-Motor: electrical Error
40 Gas-Valve : Potentiometer Error
41 Steering angle error
42 Error Number 42
43 Error Number 43
44 Error Number 44
45 Error Number 45
46 Error Number 46
47 Fault, outlet valve, rear left
48 Fault, outlet valve, rear right
49 Wheel sensor : rear left OR Outlet valve : front right
50 Wheel sensor : rear left OR Outlet valve, front left
51 Fault, inlet valve, rear left
52 Wheel sensor : rear left OR Inlet valve : rear right
53 Wheel sensor : rear left OR Inlet valve : front right
54 Fault, inlet valve, front left
55 Fault, ASC shutoff valve
56 CAN ERROR (Short Circuit)
57 Throttle-valve signal from the DME faulty
58 CAN ERROR (Open circuit to DME1
59 Fault, ASC shutoff valve
60 Signal, term.30 faulty
61 Central blocking
62 Max. ABD-adjustment time
63 Processor fault in the control unit
64 Continuous control due to undefined signal interference
65 Wheel sensor : rear right OR Feedback-signal bad
66 Wheel sensor : rear right OR Wheel-speed sensor power supply
67 CAN ERROR
68 Wheel sensor : rear right
69 Wheel sensor : rear right
70 Error Number 70
75 ASC indication lamp
81 Inlet valve front left
82 Inlet valve front right
83 Inlet valve rear left
84 Inlet valve rear right
85 Outlet valve front left
86 Outlet valve front right
87 Outlet valve rear left
88 Outlet valve rear right
89 Power supply to low
90 Time limitation : passive switching
91 CAN ERROR
92 Pressure sensor (pre charging pump)
94 RPM Sensor (Test)
95 Activation
96 Actuator Test
97 ASC Intake valve / Steering angle sensor
98 Separate valve
99 Electro magnetic switch over valve
100 Electro magnetic switch over valve
103 Brake light switch
104 Steering angle sensor
105 Brake light switch
106 Lateral acceleration sensor
107 RPM sensor (Gradient)
113 ABS /ASC feed back pump
115 ABS/ASC control unit : internal error
118 Electromagnetic or mechanical influence on the wheel speed signals
120 Power supply to high (> 18V)
129 ABS/ASC Main Relay circuit faulty
130 Power supply faulty at the magnetic valves
131 Wrong currant at magnetic valves
133 Power supply > to high
145 CAN chip in the ABS/ASC control unit
146 CAN ERROR
147 CAN ERROR : Engine Intervention
148 CAN ERROR : Engine speed (RPM)
149 CAN ERROR : DME/DDE connection
150 CAN ERROR : EGS
151 Coding ERROR
152 DSC button
161 RPM Sensor
162 RPM Signal
163 Lateral acceleration sensor
164 Lateral acceleration sensor
165 Pressure sensor 1
166 Pressure sensor 2
167 Pressure sensors
168 Pressure sensors Power Supply
177 Pre charge pump
178 Pre charge pump
180 Steering angle sensor (signal 1)
181 Steering angle sensor (identification)
182 Steering angle sensor (CAN)
183 Steering angle sensor (internal)
184 Steering angle sensor (offset)
Old Oct 17, 2014 | 09:53 PM
jamfred774's Avatar
jamfred774
So I used the c110 to read the wheel speeds and it was rather interesting. The front right was listing as much faster than the other three. 10kph at highway speeds.
At low speed when the traction control went nuts the three that were the same listed 86kph and the front right was at 8kph (which was the speed I was going.)
Old Oct 22, 2014 | 11:18 AM
jamfred774's Avatar
jamfred774
I replaced my front right wheel bearing and it fixed my issues. The magnet was reading way off which was throwing my system for a loop.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
