Super Knock Cylinder 3
Old Oct 14, 2014 | 06:08 PM
wzabrouski's Avatar
wzabrouski
About 63k miles. Is this a sign of a need to have a carbon cleaning completed? I have read numerous threads pointing me in that direction. I did fill up today... Maybe bad gas?
Old Oct 15, 2014 | 08:03 AM
EuroTechsAZ's Avatar
EuroTechsAZ
N18's don't have carbon build up problems. Might be bad gas but if you are spraying Meth it should not throw those codes since you are adding that octane boost. What map are you running when the codes are throw? With meth or no?
Old Oct 15, 2014 | 11:58 AM
wzabrouski's Avatar
wzabrouski
I was running Ca at the time.
Old Oct 15, 2014 | 12:43 PM
cerenkov's Avatar
cerenkov
Isn't C the race gas map? What's your meth flow rate?
Old Oct 15, 2014 | 01:28 PM
wzabrouski's Avatar
wzabrouski
500cc per minute
Old Oct 17, 2014 | 08:03 PM
cerenkov's Avatar
cerenkov
Any on this? Has is happened again?
Old Oct 17, 2014 | 09:45 PM
wzabrouski's Avatar
wzabrouski
No. Maybe bad gas. I did drop back down to the B map.
Old Nov 17, 2014 | 05:00 PM
cerenkov's Avatar
cerenkov
Have you figured out your P2C57 code? Does this happen when you're using the stock map?
You stated that this happens when cruising on the highway and you go to accelerate around someone. Generally these are high load situations that are a recipe for knock (if you keep it in high gear and not downshift).
Old Nov 18, 2014 | 04:37 AM
wzabrouski's Avatar
wzabrouski
I have not had it since fixing the small leak at the meth jet right angle adapter. I will probably know for sure this week as I have a few long trips on the highway this week. I have an auto so it would be downshifting on its own. Have not noticed if it happens when using the paddles.
minimacattack
Metroplex MINI - Texas
Oct 18, 2016 01:24 PM
Fordgt4
Oct 10, 2015 10:42 AM
pkillur
Sep 26, 2015 01:57 PM
minimacattack
Sep 25, 2015 07:37 PM
Mikal68
Sep 25, 2015 04:09 PM
