R56 R56 roof rack
Old Oct 14, 2014 | 03:47 AM
imncrxtc's Avatar
imncrxtc
R56 roof rack
Guys, i m looking to purchase a set of used oem roof bars for my 2008 justa, but i cant for the life of me find the mounting points on the car.
Old Oct 15, 2014 | 05:32 AM
Cngizbleevng's Avatar
Cngizbleevng
Do a search. I've come across threads regarding roof rack installation before on here.
Old Oct 15, 2014 | 06:43 AM
MikewithaMini's Avatar
MikewithaMini
There are several good DIY articles here on locating the perforations in the rain gutter that need to be cut out. I've found after installing 2 of them that good eye sight and the right lighting helps a bunch!
Old Oct 16, 2014 | 06:34 AM
cantcode86's Avatar
cantcode86
Mike said it best. you have to catch them just right to find the cutouts. I found a car at a dealership to look at to get better understanding of what to look for. They are tricky to find.
Old Oct 18, 2014 | 09:34 PM
Zillon's Avatar
Zillon
Best writeup I've found for roof rack installation is here: http://turn17.com/?p=261
Old Apr 10, 2015 | 06:10 AM
Blackwolf's Avatar
Blackwolf
Oem roof rack install is not difficult. A little tedious yes but mainly as I didn't want to scratch the roof. I watched the mini sessions video for help on install. The unscrewing until the feet popped out was key it did take some nudging though. However getting it back off was a whole new issue. To get the feet popped out once it was on took me two screw drivers for prying and leverage then some arguing. If there's an easier way I'd love to know it.
Old Apr 10, 2015 | 06:19 AM
Helix13mini's Avatar
Helix13mini
Yes, but employ the 'measure twice, cut once' technique on the rails.
Old Apr 10, 2015 | 06:27 AM
Blackwolf's Avatar
Blackwolf
Easiest way to find the mounting points is to take a bright flashlight aimed straight down into the rain channel. As your slowly moving down the line you can see the perforations. Once you find those insert the slim card and slightly pull towards you to find the vertical indentations. Then tear out.
1chaos52
Aug 24, 2015 01:28 PM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:19 PM
Aug 11, 2015 12:18 PM
