R50/53 Hotchkis rear camber link
Old Oct 13, 2014 | 10:45 AM
Alexalvarez's Avatar
Alexalvarez
Hello everyone , read online that Hotchkis makes the best rear camber links, however all I see is lower camber link , I need the upper ones, they wanna make me by the whole kit if I need the upper ones, I don't see them as just a pair like the lower ones, are the upper and lower the same? Thanks for your help in advance
Old Oct 13, 2014 | 11:09 AM
myles2go's Avatar
myles2go
You can use the same for upper and lower.
Old Oct 13, 2014 | 08:16 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The upper and lower pairs are the same.
So just order our lower Hsport pair, and I have a few extra of the headlight leveler brackets I can throw one in the box if you need.
http://www.waymotorworks.com/h-sport...ber-links.html
Old Oct 15, 2014 | 12:06 AM
Alexalvarez
Thanks guys! , much appreciated
Old Oct 15, 2014 | 01:03 AM
Alexalvarez
Also have one more question guys, okay first off what I am doing is trying to fit wide wheels, most of you guys aren't into the "stance" look on here but I need to get the most negative camber front and rear , the camber links should be enough sicne they go to -4 but what about the front? I have ksport coilovers and the camber plates don't give me enough, how can I get the most negative camber in the front?
W0TM8
Dec 19, 2019 07:50 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
