P0055 code states sensor 3
Old Oct 4, 2014 | 11:00 AM
celticfc's Avatar
celticfc
My 2010 Cooper S quit on the highway and had a significant misfire when I tried to re-start it. I had it towed home and checked the fault codes SES was on also. There are 8 code instances primarily referencing multiple cylinder misfires and calls out cylinder 2 on 3 instances. I also get a P0055 code that states O2S heater resistance bank 1 sensor 3. This has confused me because I can only find 2 O2 sensors. One on the down pipe and one behind the catalyst. Does anyone know which sensor this relates to? One more question, one of the codes listed was C342D, I can find no reference of this anywhere. Does anyone know what it is?
Old Oct 4, 2014 | 05:25 PM
AZdsrt's Avatar
AZdsrt
I couldn't find anything specific to C342D other than the C stands for chassis, and the 4 stands for emissions.
Old Jun 11, 2016 | 04:53 PM
jamadeus's Avatar
jamadeus
Hello, celticfc. Did you resolve the issue? I have 2010 Cooper Justa and yesterday I got the same codes as yours - multiple cylinder misfires and P0055 and C342D.
TIA
jh
Old Jun 13, 2016 | 05:51 AM
celticfc's Avatar
celticfc
TIA
jh
Final diagnosis was burnt out valves on # 2 and 4 cylinders. Pretty much fried the motor. I ended up buying a used motor rather than trying to rebuild it. That P0055 I think is only diagnosable through the BMW service tester. I would suggest you do a compression check as a starting point.
Good luck
Old Jun 13, 2016 | 11:08 AM
jamadeus's Avatar
jamadeus
Thanks, celticfc. That is what I was afraid to hear. I'm not good with the cars and I might need to take it into the indi shop for diagnostics. Do you know what would have caused that failure? what i have done before I noticed something was to put the Chvron system cleaner. I have done so many times in the past and I noticed the decreased MPG and power, so I got some from Amazon and put it in about 2 weeks ago. My wife told me something is not right with the car after putting it in - engine is louder than before, according to her. And last friday after work when i hit the accelerator to merge into freeway, the car shook and misfires. I got home somehow, but the car is still rough at idle with all the codes.
But thanks for the quick response.
jh
Svejk
Feb 24, 2019 12:18 PM
mdutton11
14
Oct 26, 2015 01:47 PM
PSIChocolate
Aug 13, 2015 12:46 PM
massmini03
Aug 12, 2015 11:19 AM
