:: ECS Tuning :: More "MINI" Wheels ON Sale (R99 & 5) & H&R Sport Springs !
R50 R52 R53 MINI Cooper R95 & R99 Wheel Sets
Two new genuine MINI wheel offerings are now available from ECS.
BBS 17-inch double spoke polished finish alloy and JCW 18-inch 5 star spoke silver paint finish alloy wheels look right at home on the R50/R52/R53 Cooper, adding a performance look that fits the MINI.
Both styles are conveniently available in sets of four, and because these are original factory equipment, quality and fitment are guaranteed.
The Real Deal
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible / S / JCW (2005-2008)
Click HERE for MINI wheel sets
R56-R59 MINI Cooper R95 & R99 Wheel Sets
BBS 17-inch double spoke polished finish alloy and JCW 18-inch 5 star spoke silver paint finish alloy wheels look right at home on the R56-R59 Cooper, adding a performance look that fits the MINI.
The Real Deal
Fits MINI:
R56 Cooper /S/JCW (2007+)*
R55 Cooper Clubman /S/JCW (2008+)*
R57 Cooper /S/JCW (2009+)*
R58 Coupe' /S/JCW (2012+)*
R59 Roadster /S/JCW (2012+)*
*JCW 4 Piston Brake kits will need 20mm spacer for wheel fitment.
Click HERE for the MINI Wheel Sets
R56/R57/R55 MINI Cooper SPC Front Camber Plates
For track-ready cars like the R56/R57/R55 MINI, suspension adjustability yields huge gains in handling characteristics.
SPC Performance Front Adjustable Camber Plates are an excellent investment for the MINI owner looking to dial in a more aggressive front camber and caster specification, keeping the tire contact patch more parallel with the road surface during hard cornering when traction is most needed.
The aluminum plates are coupled with an OE-style bearing within a bonded urethane insulator, allowing for +/- 2 degrees of camber and +/- .75 degrees of caster adjustment.
Dialed in Performance
Fits :
R56 MINI Cooper /S/JCW (2007+)
R55 MINI Clubman /S/JCW (2008+)
R57 MINI Cooper Convertible /S/JCW (2009+)
Click HERE for SPC front Camber Plates .
R60 R61 MINI Hella Twin Supertone Horns
Hella Twin Supertone Horns are now available for your MINI.
These horns are characterized by their strong penetrating and concentrated sound, making anyone within a sizable distance aware of your presence.
All of Hella's horns are constructed with durability in mind from impact resistant plastic and feature a 400 Hz low tone and 500 Hz high tone horn.
All kits include the horns, relay, and mounting brackets.
Be heard.
Fits:
R60 MINI Countryman /S/SX/JCW (2011+)
R61 MINI Paceman /S/SX/JCW (2013+)
Click HERE for Hella horns. .
MINI R57 Adjustable Rear Control Arms
SPC Performance Adjustable Rear Control Arms are an excellent investment for the R57 MINI owner looking to dial in a more aggressive camber specification, keeping the tire contact patch more parallel with the road surface during hard cornering when traction is most needed.
The beautiful silver-anodized finished arms coupled with SPC "Red" nuts provide a full +/- 4.0 degrees of rear camber adjustment, giving you needed control over this critical parameter.
Fits:
Click HERE for SPC rear control arms sets .
R56 MINI Cooper S/JCW H&R Sport Springs
The most popular spring in H&R's line-up, Sport Springs will lower your MINI an average of 1.4 inches for a lower center of gravity, improved handling, and a more aggressive appearance.
Sport springs are an excellent choice for street and occasional track use, featuring a spring rate that is firmer than the OE Sport spring but still comfortable enough for daily use.
Lowering : 1.4 Front / 1.4 Rear
A Tasteful Upgrade
Fits:
R56 MINI Cooper S/JCW (2007+)
Click HERE for the H&R Sport Springs
Jan 4, 2019 12:51 PM
Aug 10, 2015 02:03 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
