Greenish fluid leak?
Old Oct 1, 2014 | 06:24 PM
goldcountrymini's Avatar
goldcountrymini
Hello,
I had some oily fluid leak towards the right front of my 2011 MCS. any idea what thus could be? Seems to be the opposite side of the coolant resevoir and as I understand that, the coolant is blue in color. This would have been about 6-8 inches from the right front tire towards the center of the engine.
Thanks in advance.
Old Oct 1, 2014 | 07:44 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by goldcountrymini
Hello,
Mini coolant is indeed blue. Are you the first owner? Did you bring it anywhere where the fluid might have been exchanged for non-Mini fluid? The other fluid is oil which is also not green. And A/C drainage would be colorless.
///Rich
Old Oct 2, 2014 | 02:23 AM
goldcountrymini
///Rich
Thanks for the reply. I'm the second owner. I have not taken it anywhere that would have swapped, but maybe the other owner. It didn't have a sweet smell like coolant
Old Oct 2, 2014 | 07:04 AM
v10climber's Avatar
v10climber
Probably the water pump. Common failure on these cars. It's on the passenger side of the engine. They start weeping when they need replacing.
Old Oct 10, 2014 | 02:52 AM
goldcountrymini
Interesting. Thank you. I I have had this happen now twice, but not consecutively. My 2011 MCS is only at 33k miles...
Old Oct 11, 2014 | 10:28 AM
Systemlord's Avatar
Systemlord
Wait a minute I though Mini coolant was green and on the thick side? Recently had pump replaced (aluminum version) at CarMax and now have blue coolant in reservoir.
Old Oct 11, 2014 | 11:57 AM
ZippyNH's Avatar
ZippyNH
BMW/mini coolant is blue....looks like blue Gatorade....same thickness diluted as any other coolant.
Old Oct 15, 2014 | 05:09 PM
mbwicz's Avatar
mbwicz
If you can jack up the car (or get it on ramps), you can see if the water pump is leaking from either under the car (look up just above at the rear of the oil pan) or behind the front wheel (look at the side of the engine).
There should be some witness of what is leaking on the side of the engine. My guess is water pump as well. Oil would be brown, trans fluid would be oily and red/brown. There is no power steering fluid on our cars. The only other fluids are windshield washer (not in that area) or brake fluid (not green).
Mike
boholio
Nov 9, 2015 03:50 PM
IFIXEM2
Sep 18, 2015 08:47 AM
Sep 10, 2015 03:36 PM
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
