Cooper (non S) Modifications specific to the MINI Cooper (R56).
R56 Front Brakes Sensor
Old Oct 1, 2014 | 07:00 AM
mkoutnik's Avatar
mkoutnik
How many brake wear sensors are needed on the front? I'm replacing pads and rotors on the front.
http://www.ecstuning.com/Mini-2009-C...ors/ES2018160/
Old Oct 1, 2014 | 07:24 AM
Mini2na's Avatar
Mini2na
One. Driver's side.
Old Oct 1, 2014 | 07:26 AM
mkoutnik's Avatar
mkoutnik
Thank you!
Old Oct 1, 2014 | 07:43 AM
+1 one on the front left ( driver side). Just clip it back in location like the old one. I start clipping the old one out while clipping the new one so it follows the same exact location and bends / clips on the ABS and such.
http://www.ecstuning.com/Mini-2009-Cooper-R56-Base-Coupe-L4_1.6L_N12B16A/Braking/Sensors/ES2018160/
Old Oct 1, 2014 | 02:50 PM
mkoutnik's Avatar
mkoutnik
What size Torx driver removes the rotor?
Old Oct 2, 2014 | 10:31 AM
It marked on the brake rotor set screw which I would replace whenever doing brakes as the old ones with corrode and stick. out a little anti-seize on the thread of a new one.
Torx head takes T50 size for install. 1 screws per rotor.
Link to 2009 R56 MINI Cooper Base ( Non S ):
http://www.ecstuning.com/Mini-2009-Cooper-R56-Base-Coupe-L4_1.6L_N12B16A/Braking/Rotors/
Toolman
Jan 20, 2016 06:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
JPMontes3
Aug 23, 2015 01:26 AM
