Advice: Changing original plugs, how hard to crank Seized??
Old Sep 26, 2014 | 08:13 PM
blkisuz's Avatar
blkisuz
my original plugs are on my JCW 2004 MINI S
Went to put new plugs in at 128k and they aren't budging.
How hard do I crank or should I take it to the dealer? They aren't budging with full shoulder strength on the tool. Are they seized? Is there something I could spray down there to loosen them?
Old Sep 27, 2014 | 01:34 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
The dealer has no magic to get the plugs out. If one snaps it snaps!
I would have to use my 24" breaker bar on this job. Presuming the plug comes out buy/borrow/hire the correct tap, cover it in grease and chase the thread.
Use plug grease/never sieze in the new set.
If one snaps -at leaset you didn't have to pay someone to snap it for you. The repair cost would be the same, as the dealer will not take the blame..
Old Sep 27, 2014 | 02:40 AM
jkapinos's Avatar
jkapinos
I would spray some PB down in the spark plug holes and let them soak for up to 24 hours and then give it a try then. Good luck.
Old Sep 27, 2014 | 04:41 AM
mrbean's Avatar
mrbean
I would recommend kanokroil instead of PB. It's f-ing magic. Make sure the engine is stone cold when cranking on the plug and go easy on it.
When/if the plug breaks free, back it out slowly. If it feels like the threads are starting to bind up again (even slightly), thread it back in a 1/2 turn and back it out again. Repeat this until it's completely free. This has been a fail proof method for me; I've never stripped a spark plug thread in 20 some odd years of working on cars.
Old Sep 28, 2014 | 08:44 AM
blkisuz's Avatar
blkisuz
KanoKroil Gets My Endorsement!! Sweet Success
Drove 50 miles round trip to get the Kanokroil even though I had the PB in the garage, Not taking any chances! and Success! Blackeyedsuzie Always my Faithful! gave up the old spark plugs in favor of new equipment and a special bath!
You Betcha I talked her all the way through it!
Old Sep 28, 2014 | 06:59 PM
WhoHasGotTheBlueS's Avatar
WhoHasGotTheBlueS
Did you really think the Kanokroil really work better than PB Blaster??? You've used PB but gave it up for something you never used before...
Old Sep 28, 2014 | 07:22 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes try the Kanokroil that stuff is good.
If it still doesn't work better, try to warm the car up for a minute. Not full temp, but just a little heat in the engine may make them come out.
blackie
Sep 2, 2015 09:16 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
Dashdog
Aug 10, 2015 06:17 AM
