Engine noise from 04 Cooper S
Old Sep 26, 2014 | 08:18 AM
OrlandoCooperS's Avatar
OrlandoCooperS
Good morning,
When my engine is idling, I can hear a rattling from the engine. When I gently rev it, it sounds like marbles bouncing up and down.
I don't hear it when I'm outside of the vehicle, only when I'm inside.
The oil is fresh, but I'm wondering if it's bearings making the noise.
Also, sometimes when I'm driving fast, I smell something burning through the vents in the car.
Any idea what are causing my issues?
Thanks in advance.
Old Sep 26, 2014 | 08:45 AM
MikeN's Avatar
MikeN
Probably the timing chain tensioner is failing and you need to replace it. Not that difficult to do. Check out youtube, there is an instructional video on it. You should pop the hood and listen to where it is exactly coming from though first. Hopefully it isn't a spun rod bearing.
The smell could be oil seeping on to your exhaust and burning up.
Old Sep 26, 2014 | 10:44 AM
ZippyNH's Avatar
ZippyNH
Have someone press the clutch in and listen to see if the sound goes away...
If it does, it is the throwout bearing...part of the clutch.
Old Sep 26, 2014 | 10:48 AM
AudioNToxication's Avatar
AudioNToxication
What does the burning smell like specifically. Oil? Coolant? Rubber?
Old Sep 26, 2014 | 11:13 AM
OrlandoCooperS
I don't think it smells like any of those, actually. Having previously driven a 99 Miata for years, I'm veeeeery familiar with oil and coolant smells.
Any other ideas?
Old Sep 26, 2014 | 11:14 AM
OrlandoCooperS
Okay. I'll have someone help me with this.
Old Sep 26, 2014 | 11:16 AM
OrlandoCooperS
Thanks, but the tensioner was changed 2 weeks ago, but the sound is still there. Any other ideas?
Old Sep 26, 2014 | 11:24 AM
ForcedFed4's Avatar
ForcedFed4
idk sounds like the SC is going out to me...
Old Sep 26, 2014 | 06:19 PM
AudioNToxication
Check your crank damper. Loosen the belt and wiggle it, it may be coming apart.
Old Sep 26, 2014 | 07:42 PM
MIN16G's Avatar
MIN16G
I had a rattle on idle which just ended up being a worn rubber bushing on the SC tensioner hydraulic arm. Easy fix that one.
What RPM are you hearing the bag of marbles sound? definitely sounds the timing chain tensioner to me... maybe the replaced tensioner is faulty or there's bits of the tensioner guides in there?
Old Sep 27, 2014 | 06:50 AM
kaneguy's Avatar
kaneguy
Get yourself a nAutomotive stethoscope, about $10 at AutoZone. By poking around with the probe you will be able to pin point the source of the noise.
maestro39
Oct 27, 2015 02:38 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
